Ana içeriğe geç
Samsung RC512 Screen Replacement
Neye ihtiyacın var
  1. Samsung RC512 Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Place the laptop upside down.
  2. Samsung RC512 Screen Replacement: adım 2, 2 resimden 1. Samsung RC512 Screen Replacement: adım 2, 2 resimden 2.
    • Locate two notches above the battery.
    • Slide both battery locking notches to either side to remove the battery.
    • Pull the battery out.
  3. Samsung RC512 Screen Replacement, Screen: adım 3, 3 resimden 1. Samsung RC512 Screen Replacement, Screen: adım 3, 3 resimden 2. Samsung RC512 Screen Replacement, Screen: adım 3, 3 resimden 3.
    • The Laptop should be off before removing the battery.
  4. Samsung RC512 Screen Replacement: adım 4, 3 resimden 1. Samsung RC512 Screen Replacement: adım 4, 3 resimden 2. Samsung RC512 Screen Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove the gray covers with tweezers to expose the 4mm screws.
    • Using a Phillips #0 screwdriver, remove the four 4 mm Phillips #0 screws.
  5. Samsung RC512 Screen Replacement: adım 5, 2 resimden 1. Samsung RC512 Screen Replacement: adım 5, 2 resimden 2.
    • Insert the blue plastic opening tool into the bezel and rear housing of the screen.
    • Use the plastic opening tool to pop open the claps that hold the casing on the screen.
    • Work your way around the sides carefully and continue this to the bottom.
    • You may use your fingers to help remove the cover.
  6. Samsung RC512 Screen Replacement: adım 6, 2 resimden 1. Samsung RC512 Screen Replacement: adım 6, 2 resimden 2.
    • With the Phillips #0 screwdriver remove the six 3 mm screws, which mount the screen onto the base of the laptop.
    • As you remove the last two screws, support the screen. As the screws are taken out, the screen will begin to fall forward.
  7. Samsung RC512 Screen Replacement: adım 7, 3 resimden 1. Samsung RC512 Screen Replacement: adım 7, 3 resimden 2. Samsung RC512 Screen Replacement: adım 7, 3 resimden 3.
    • Gently lay the LCD onto the keyboard.
    • Do not separate the LCD screen and the back panel from each other. The video connector still connects the two together.
    • Remove the tape that secures the video connector to the LCD screen with tweezers.
    • Grasp the video connector at its base and pull it away from the LCD screen.
    • The only thing holding the screen will be the clear tape causing it to come out easily.
Sonuç
Bir başkası bu kılavuzu tamamladı.
jando
917 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 18-2, Blackwell Fall 2016 USF Tampa, Team 18-2, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S18G2
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 754
