Giriş
This guide shows how to remove and replace the control board in your Samsung RF28R7201SG refrigerator.
The control board controls the refrigerator's functions. It also has a DC power board built into it. If your refrigerator turns on but doesn't function properly, check the components related to the function first. Replace the control board only after you've verified the other components.
Neye ihtiyacın var
Use a Phillips screwdriver to remove the five screws securing the board access panel to the back of the refrigerator:
Four 14.8 mm-long screws
One 12.3 mm-long screw
Three connectors along the top edge
One connector along the right edge
One connector along the bottom edge
Four connectors along the left edge
Pull and disconnect each of the nine connectors from the control board.
Move the wires away from the control board so it can slide out of its recess.
Repair didn’t go as planned? Ask our Answers community for help.
