Giriş
This guide shows how to remove and replace the fuse block or fuse board in your Samsung RF28R7201SG refrigerator.
The fuse block contains a number of fuses soldered on a circuit board and is made to be replaced as a whole unit. If your refrigerator doesn't power on at all, you may need to replace the fuse block.
Neye ihtiyacın var
Use a Phillips screwdriver to remove the five screws securing the board access panel to the back of the refrigerator:
Four 14.8 mm-long screws
One 12.3 mm-long screw
Squeeze the wide sides of the red connector to unlatch it from the fuse block.
Pull to disconnect the connector.
Repeat the procedure to disconnect the blue connector.
Repair didn’t go as planned? Ask our Answers community for help.
2 farklı kişi bu kılavuzu tamamladı.
