Ana içeriğe geç
Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement
Neye ihtiyacın var
  1. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Unplug your refrigerator: adım 1, 1 resimden 1.
    • Unplug your refrigerator before you begin your repair.
  2. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Open the refrigerator doors: adım 2, 2 resimden 1. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Open the refrigerator doors: adım 2, 2 resimden 2.
    • Open both French doors for the refrigerator compartment.
  3. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the ice tray: adım 3, 3 resimden 1. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the ice tray: adım 3, 3 resimden 2. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the ice tray: adım 3, 3 resimden 3.
    • Pull the ice tray straight out of its housing and remove it.
  4. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Unfasten the cable cover panel: adım 4, 2 resimden 1. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Unfasten the cable cover panel: adım 4, 2 resimden 2.
    • Use a Phillips screwdriver to remove the 16.5 mm‑long screw securing the cable cover panel.
  5. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the cable cover panel: adım 5, 3 resimden 1. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the cable cover panel: adım 5, 3 resimden 2. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the cable cover panel: adım 5, 3 resimden 3.
    • Use your fingers to slide the cable cover panel towards the front of the refrigerator to unlatch it.
    • Remove the cable cover panel.
    • During reassembly, make sure this panel clips fully in place, or the ice tray won't slide in properly.
  6. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker harness: adım 6, 2 resimden 1. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker harness: adım 6, 2 resimden 2.
    • Disconnect the left-most yellow connector:
    • Squeeze the locking tab with the red mark with your fingers
    • Rock the connector gently side to side to disconnect it
    • Use your fingers or a screwdriver to guide the wire harness out of the wall clips.
  7. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Unfasten the air tunnel: adım 7, 1 resimden 1.
    • Use a Phillips screwdriver to remove the 16.5 mm-long screw securing the air tunnel flap.
  8. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: adım 8, 3 resimden 1. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: adım 8, 3 resimden 2. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: adım 8, 3 resimden 3.
    • A plastic clip holds the air tunnel flap in place.
    • Use a flathead screwdriver to pry and loosen the air tunnel flap from the plastic clip.
  9. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: adım 9, 2 resimden 1. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: adım 9, 2 resimden 2.
    • Use your fingers to pull the air tunnel flap down enough to access the internals.
  10. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: adım 10, 2 resimden 1. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: adım 10, 2 resimden 2.
    • Use a flathead screwdriver to gently pry the refrigerant loop down by 1–1.5 cm.
    • During reassembly, use your fingers to push the refrigerant loop back up.
  11. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: adım 11, 3 resimden 1. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: adım 11, 3 resimden 2. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: adım 11, 3 resimden 3.
    • A plastic clip holds the icemaker in place.
    • Use your fingers to press and release the plastic clip.
    • This clip is stiff and may require substantial force.
  12. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: adım 12, 2 resimden 1. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: adım 12, 2 resimden 2.
    • Pull the front edge of the icemaker assembly down slightly to loosen it.
    • Be careful not to bend the refrigerant loop too much as you pull the front edge, or you'll damage the loop.
    • Carefully slide the icemaker assembly out of its housing.
  13. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: adım 13, 2 resimden 1. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: adım 13, 2 resimden 2.
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15.927 İtibar
88 adet Kılavuz yazıldı
Ekip
Global Fixers Global Fixers üyesi
Community
33 Üyeler
574 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 41
Son 30 gün: 107
Her zaman: 582
