Ana içeriğe geç
Samsung RF28R7351 Fuse Block Module Replacement
Neye ihtiyacın var
Videoya Genel Bakış
    1. Samsung RF28R7351 Fuse Block Module Replacement, Fuse Box Module: adım 1, 1 resimden 1.
      • Begin by disconnecting the power to the appliance
      • It is also recommended to test the outlet for the proper voltage
      • Also, turn off the water.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung RF28R7351 Fuse Block Module Replacement: adım 2, 1 resimden 1.
      • You will need a Phillips screwdriver to remove the cover, which is held on by five Phillips screws.
      • Remove the five Phillips screws.
      • The lower middle screw is a machine screw thread, so keep it separate for reinstallation.
      FixBot'a Sor
      Yorum Ekle
    3. FixBot'a Sor
      Yorum Ekle
    4. Samsung RF28R7351 Fuse Block Module Replacement: adım 4, 2 resimden 1. Samsung RF28R7351 Fuse Block Module Replacement: adım 4, 2 resimden 2.
      • With the panel removed, you now have clear access to the fuse block.
      FixBot'a Sor
      Yorum Ekle
    5. Samsung RF28R7351 Fuse Block Module Replacement, Test continuity of fuses: adım 5, 2 resimden 1. Samsung RF28R7351 Fuse Block Module Replacement, Test continuity of fuses: adım 5, 2 resimden 2.
      • The main reason why you'd be accessing your fuse block is if the unit has no power
      • Once the fuse block is removed, you can use your multimeter to test continuity on the metal sides of each one of these fuses.
      • (How to use a multimeter)
      • If one is blown, the fuse block will need to be replaced.
      FixBot'a Sor
      Yorum Ekle
    6. Samsung RF28R7351 Fuse Block Module Replacement, Disconnecting the fuse block: adım 6, 2 resimden 1. Samsung RF28R7351 Fuse Block Module Replacement, Disconnecting the fuse block: adım 6, 2 resimden 2.
      FixBot'a Sor
      Yorum Ekle
    7. Samsung RF28R7351 Fuse Block Module Replacement, Installing a new fuse block: adım 7, 2 resimden 1. Samsung RF28R7351 Fuse Block Module Replacement, Installing a new fuse block: adım 7, 2 resimden 2.
      • When installing your new fuse block, first install the wiring.
      • Make sure the connector is securely locked into place.
      • The red wire goes with the red, and the blue with the blue.
      • Swing it in at an angle and pop it in place.
      FixBot'a Sor
      Yorum Ekle
    8. Samsung RF28R7351 Fuse Block Module Replacement, Reinstall the panel cover: adım 8, 1 resimden 1.
      • Once the new fuse block is installed, you can reinstall the panel cover.
      • To reinstall your panel cover, first bring in the top at an angle and drop it on those hooks.
      FixBot'a Sor
      Yorum Ekle
    9. Samsung RF28R7351 Fuse Block Module Replacement: adım 9, 3 resimden 1. Samsung RF28R7351 Fuse Block Module Replacement: adım 9, 3 resimden 2. Samsung RF28R7351 Fuse Block Module Replacement: adım 9, 3 resimden 3.
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
eCuration
478.744 İtibar
396 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 14
Son 30 gün: 53
Her zaman: 803
