Ana içeriğe geç
Samsung SCV-VLUUST50 Flash Capacitor Replacement
Evert Jordan
Evert Jordan ve başka bir katkıda bulunan
En son November 17, 2020 tarihinde güncellendi
15 dakika
Orta
Is your flash weak or not working at all? It could be your flash capacitor. Here's a replacement guide to help.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Samsung SCV-VLUUST50 Flash Capacitor Replacement, Cover: adım 1, 3 resimden 1. Samsung SCV-VLUUST50 Flash Capacitor Replacement, Cover: adım 1, 3 resimden 2. Samsung SCV-VLUUST50 Flash Capacitor Replacement, Cover: adım 1, 3 resimden 3.
    • Unscrew all visible screws indicated by red circles with a #00 Phillips driver.
    • Slide memory card cover and unscrew hidden screw underneath with a #00 Phillips driver.
  2. Samsung SCV-VLUUST50 Flash Capacitor Replacement: adım 2, 3 resimden 1. Samsung SCV-VLUUST50 Flash Capacitor Replacement: adım 2, 3 resimden 2. Samsung SCV-VLUUST50 Flash Capacitor Replacement: adım 2, 3 resimden 3.
    • Remove the flat side panel by applying gentle pressure toward the bottom of the camera.
    • Remove the corner panel by applying pressure away from the shutter button.
    • The memory card cover will come off with the corner panel.
    • Remove the top panel by applying gentle pressure away from the shutter button.
  3. Samsung SCV-VLUUST50 Flash Capacitor Replacement: adım 3, 1 resimden 1.
    • Remove screws beneath the top panel indicated by red circles with a #00 Phillips driver.
  4. Samsung SCV-VLUUST50 Flash Capacitor Replacement: adım 4, 2 resimden 1. Samsung SCV-VLUUST50 Flash Capacitor Replacement: adım 4, 2 resimden 2.
    • Remove the front and back covers by pulling them straight apart.
  5. Samsung SCV-VLUUST50 Flash Capacitor Replacement, Flash Capacitor: adım 5, 2 resimden 1. Samsung SCV-VLUUST50 Flash Capacitor Replacement, Flash Capacitor: adım 5, 2 resimden 2.
    • Remove the screw securing the shutter button.
    • Lift the shutter button to remove it.
  6. Samsung SCV-VLUUST50 Flash Capacitor Replacement: adım 6, 2 resimden 1. Samsung SCV-VLUUST50 Flash Capacitor Replacement: adım 6, 2 resimden 2.
    • Remove the 3 visible screws with a Phillips #000 Driver
    • Move the circuitry and wires out of the way to expose another screw, and remove it with the same driver.
  7. Samsung SCV-VLUUST50 Flash Capacitor Replacement: adım 7, 3 resimden 1. Samsung SCV-VLUUST50 Flash Capacitor Replacement: adım 7, 3 resimden 2. Samsung SCV-VLUUST50 Flash Capacitor Replacement: adım 7, 3 resimden 3.
    • Pull the flash capacitor out of its compartment to expose the wires connected to it.
    • Cut the connecting wires with wire cutters.
    • Solder the wires to the new power source with a soldering iron and electrical solder.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 198
