Ana içeriğe geç
Samsung StormWash DW80R5061 Drain Pump Hose Replacement
Neye ihtiyacın var
  1. Samsung StormWash DW80R5061 Drain Pump Hose Replacement, Inner Drain Pump Hose: adım 1, 3 resimden 1. Samsung StormWash DW80R5061 Drain Pump Hose Replacement, Inner Drain Pump Hose: adım 1, 3 resimden 2. Samsung StormWash DW80R5061 Drain Pump Hose Replacement, Inner Drain Pump Hose: adım 1, 3 resimden 3.
    • Remove the power cord from the electrical outlet.
    • If your Dishwasher is hardwired, you will need to refer to a different guide or your user manual for instructions to turn off the power through the circuit breaker.
  2. Samsung StormWash DW80R5061 Drain Pump Hose Replacement: adım 2, 3 resimden 1. Samsung StormWash DW80R5061 Drain Pump Hose Replacement: adım 2, 3 resimden 2. Samsung StormWash DW80R5061 Drain Pump Hose Replacement: adım 2, 3 resimden 3.
    • Shut off the water supply valve following the direction of the indicator on the valve.
  3. Samsung StormWash DW80R5061 Drain Pump Hose Replacement: adım 3, 2 resimden 1. Samsung StormWash DW80R5061 Drain Pump Hose Replacement: adım 3, 2 resimden 2.
    • Use a flathead screwdriver to loosen hose clamp that secures the drain hose.
    • Disconnect the drain hose from the sink or garbage disposal unit.
    • Push the drain hose out of the cabinet, threading through the hole the hose is located in.
    • Use a 5/8 inch or 24mm wrench to remove the water supply line from the dishwasher rear.
  4. Samsung StormWash DW80R5061 Drain Pump Hose Replacement: adım 4, 3 resimden 1. Samsung StormWash DW80R5061 Drain Pump Hose Replacement: adım 4, 3 resimden 2. Samsung StormWash DW80R5061 Drain Pump Hose Replacement: adım 4, 3 resimden 3.
    • Open the dishwasher door, and use a Phillips screwdriver to unscrew the mounting bracket screws from under the table top on the left and right.
    • Use a Phillips screwdriver to remove the screws along the left and right sides of the dishwasher.
  5. Samsung StormWash DW80R5061 Drain Pump Hose Replacement: adım 5, 3 resimden 1. Samsung StormWash DW80R5061 Drain Pump Hose Replacement: adım 5, 3 resimden 2. Samsung StormWash DW80R5061 Drain Pump Hose Replacement: adım 5, 3 resimden 3.
    • Rotate the levelers, the circular feet at the bottom of the dishwasher, to lower the appliance.
    • Use a hex-head screwdriver to release tension on the rear adjustment screw (leveler), located along the front bottom middle of the dishwasher.
  6. Samsung StormWash DW80R5061 Drain Pump Hose Replacement: adım 6, 1 resimden 1.
    • Remove the dishwasher racks.
    • Pull or remove the dishwasher from the cabinet, and tip the dishwasher over onto its rear panel side, exposing the screws of the bottom panel and side panel.
  7. Samsung StormWash DW80R5061 Drain Pump Hose Replacement: adım 7, 3 resimden 1. Samsung StormWash DW80R5061 Drain Pump Hose Replacement: adım 7, 3 resimden 2. Samsung StormWash DW80R5061 Drain Pump Hose Replacement: adım 7, 3 resimden 3.
    • Use a Phillips head screwdriver to remove the screw that secures the bottom drip panel.
    • Open the lower panel with a flat head screwdriver.
    • Disconnect the leak sensor wire by hand.
    • The wire is connected to the drip panel.
  8. Samsung StormWash DW80R5061 Drain Pump Hose Replacement: adım 8, 3 resimden 1. Samsung StormWash DW80R5061 Drain Pump Hose Replacement: adım 8, 3 resimden 2. Samsung StormWash DW80R5061 Drain Pump Hose Replacement: adım 8, 3 resimden 3.
    • Release the spring clamps from the drain pump hose.
    • Unscrew the side panel, and remove it to reveal the inner hose.
    • Release the spring clamps from the inner hose, and pull out the hose in its entirety.
    • You may place the spring clamps from the damaged hose onto a new replacement hose. Proceed to reattach the new inner hose at the side panel, with the other end attached to the drain pump.
  9. Samsung StormWash DW80R5061 Drain Pump Hose Replacement: adım 9, 3 resimden 1. Samsung StormWash DW80R5061 Drain Pump Hose Replacement: adım 9, 3 resimden 2. Samsung StormWash DW80R5061 Drain Pump Hose Replacement: adım 9, 3 resimden 3.
    • Place the spring clamps from the damaged hose onto thereplacement hose.
    • Proceed to reattach the new inner hose at the side panel, with the other end attached to the drain pump.
  10. Samsung StormWash DW80R5061 Drain Pump Hose Replacement: adım 10, 3 resimden 1. Samsung StormWash DW80R5061 Drain Pump Hose Replacement: adım 10, 3 resimden 2. Samsung StormWash DW80R5061 Drain Pump Hose Replacement: adım 10, 3 resimden 3.
    • If you are having difficulty squeezing the clamps by hand, you could try using pliers.
    • This tank on the left side of the dishwasher may contain water.
Sonuç
Sabrina
181 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 28
Her zaman: 210
