Ana içeriğe geç
Samsung Stratosphere Display Replacement
Neye ihtiyacın var
  1. Samsung Stratosphere Display Replacement, Battery: adım 1, 1 resimden 1.
    • Using your fingers, pry along the groove at the top of the phone.
    • Pull back on the rear casing until it comes free from the device.
    • The casing will make a cracking sound as it is removed.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Stratosphere Display Replacement: adım 2, 1 resimden 1.
    • With your fingers, pry from the bottom of the battery to loosen it.
    • Lift away to remove the battery from the phone.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Stratosphere Display Replacement, Motherboard: adım 3, 1 resimden 1.
    • Locate the red and white sim card located above the battery housing.
    • Remove the sim card by sliding it downwards from its slot with your fingers.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Stratosphere Display Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove the seven silver 3mm screws securing the rear panel using the Phillips #000 screwdriver.
    • Once loosened, some screws may get stuck in the casing. Use tweezers to remove them.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Stratosphere Display Replacement: adım 5, 1 resimden 1.
    • Pry around the rear panel with a plastic opening tool to loosen it.
    • Prying too deeply may damage delicate components inside the phone.
    • Remove the rear panel from the phone with your fingers.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Stratosphere Display Replacement: adım 6, 1 resimden 1.
    • Remove the four black 3mm screws securing the motherboard with the Phillips #000 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung Stratosphere Display Replacement: adım 7, 2 resimden 1. Samsung Stratosphere Display Replacement: adım 7, 2 resimden 2.
    • Locate the flex cable attachment at the tab with a green arrow printed on top.
    • Pry from the side the arrow is pointing with your fingers.
    • The cable will audibly snap as it is removed from its attachment.
    • Let the cable hang loosely to the side of the phone.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung Stratosphere Display Replacement: adım 8, 1 resimden 1.
    • Pull the motherboard up from the side opposite the loose flex cable.
    • If necessary, use a plastic opening tool to separate the motherboard from the key pad underneath.
    • Lift to remove the motherboard from the device.
    FixBot'a Sor
    Yorum Ekle
  9. Samsung Stratosphere Display Replacement, Front Camera: adım 9, 1 resimden 1.
    • Insert a plastic opening tool into any side of the phone case to separate the keyboard from the rear panel.
    • Pry the keyboard away from the casing with the plastic opening tool.
    • The keyboard should come off with almost no force at all.
    FixBot'a Sor
    Yorum Ekle
  10. Samsung Stratosphere Display Replacement: adım 10, 1 resimden 1.
    • Remove the 7 silver 2mm screws attaching the silver metal plate to the rear panel with the Phillips #000 Screwdriver.
    FixBot'a Sor
    Yorum Ekle
  11. Samsung Stratosphere Display Replacement: adım 11, 1 resimden 1.
    • Use the plastic opening tool to carefully loosen the golden metal plate.
    • The golden metal plate is stuck to the rear panel with a strong adhesive, so a moderate amount of force may be needed.
    FixBot'a Sor
    Yorum Ekle
  12. Samsung Stratosphere Display Replacement: adım 12, 1 resimden 1.
    • Lift the gold plate with your fingers, repositioning it to slide through the keyboard casing underneath.
    • Carefully take off the keyboard casing with your fingers.
    • The golden metal plate should fit through the wide slot of the casing.
    FixBot'a Sor
    Yorum Ekle
  13. Samsung Stratosphere Display Replacement: adım 13, 1 resimden 1.
    • Slide the silver metal plate down and away from the to the flex cable and gold metal plate.
    • The metal plate is attached to springs that offer a small amount of resistance, so it will snap into place.
    FixBot'a Sor
    Yorum Ekle
  14. Samsung Stratosphere Display Replacement: adım 14, 1 resimden 1.
    • Unscrew the 4 black 3mm screws from the rear panel with the Phillips #000 Screwdriver.
    FixBot'a Sor
    Yorum Ekle
  15. Samsung Stratosphere Display Replacement: adım 15, 2 resimden 1. Samsung Stratosphere Display Replacement: adım 15, 2 resimden 2.
    • Insert the plastic opening tool into the groove at the top of the rear panel.
    • Firmly slide the plastic opening tool all around the rear panel. The panel will audibly snap as it comes apart.
    • These 2 pieces are attached well, so a significant amount of force is needed to separate them.
    FixBot'a Sor
    Yorum Ekle
  16. Samsung Stratosphere Display Replacement: adım 16, 1 resimden 1.
    • Lift the flex cable and position it so the part containing the metal plate can come free.
    • Pull the part containing the metal plate away from the rest of the rear panel.
    FixBot'a Sor
    Yorum Ekle
  17. Samsung Stratosphere Display Replacement: adım 17, 2 resimden 1. Samsung Stratosphere Display Replacement: adım 17, 2 resimden 2.
    • Use tweezers to loosen the front-facing camera from the plastic casing.
    • Pull the black rectangular piece, attached to the front facing camera, away from the rear panel.
    FixBot'a Sor
    Yorum Ekle
  18. Samsung Stratosphere Display Replacement, Flex Cable: adım 18, 1 resimden 1.
    • Carefully peel the blue tape from the bottom of the flex cable and set it aside.
    FixBot'a Sor
    Yorum Ekle
  19. Samsung Stratosphere Display Replacement: adım 19, 2 resimden 1. Samsung Stratosphere Display Replacement: adım 19, 2 resimden 2.
    • Use one of the plastic opening tools to loosen the flex cable from its central housing.
    • Pull lightly on the flex cable to free it from the housing.
    • The cable may audibly snap as it is freed from its attachment.
    FixBot'a Sor
    Yorum Ekle
  20. Samsung Stratosphere Display Replacement: adım 20, 1 resimden 1.
    • Use tweezers to loosen the flex cable and speaker from the bottom of the phone.
    • Pull upward with the tweezers and the flex cable will come loose.
    • The flex cable will come free with the front-facing camera attached. In order to remove the front-facing camera, see our guide here.
    FixBot'a Sor
    Yorum Ekle
  21. Samsung Stratosphere Display Replacement, Display: adım 21, 2 resimden 1. Samsung Stratosphere Display Replacement, Display: adım 21, 2 resimden 2.
    • Locate the clamp holding the gold display cable to the back of the screen.
    • Using the plastic opener tool, lightly pry the cable attachment into an upright position.
    • The clamp attachment will snap as it is pried upright.
    • Once completed, the attachment should resemble the marked section.
    FixBot'a Sor
    Yorum Ekle
  22. Samsung Stratosphere Display Replacement: adım 22, 1 resimden 1.
    • Using the tweezers, carefully pull the gold display cable to remove it from its attachment.
    • Be careful not to bend the display cable as this is a very sensitive part of the phone.
    FixBot'a Sor
    Yorum Ekle
  23. Samsung Stratosphere Display Replacement: adım 23, 2 resimden 1. Samsung Stratosphere Display Replacement: adım 23, 2 resimden 2.
    • Pry around the screen with a plastic opening tool to loosen it from the frame.
    • Repeat this process as necessary; a lot of adhesive holds the screen to the frame.
    • Gently push forward from the back of the display to remove the screen from the frame.
    FixBot'a Sor
    Yorum Ekle
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
William Lai
217 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 11-32, Amido Fall 2013 Cal Poly, Team 11-32, Amido Fall 2013 üyesi
CPSU-AMIDO-F13S11G32
4 Üyeler
18 adet Kılavuz yazıldı
1Rehber Yorum
Overall this was a great presentation. Very thorough and detailed, yet simple, with great pictures. Thank you.
huckleberry41 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 22
Her zaman: 4,962
