Ana içeriğe geç
Samsung WB1100F Camera Flash Replacement
Neye ihtiyacın var
    1. Samsung WB1100F Camera Flash Replacement, LCD Screen Cover: adım 1, 2 resimden 1. Samsung WB1100F Camera Flash Replacement, LCD Screen Cover: adım 1, 2 resimden 2.
      • Remove six 1.2 mm Phillips #00 screws connected to the tripod dock and adjacent screws.
      • Remove six 1.2 mm Phillips #00 screws from the side of the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung WB1100F Camera Flash Replacement: adım 2, 2 resimden 1. Samsung WB1100F Camera Flash Replacement: adım 2, 2 resimden 2.
      • Use a plastic opening tool or spudger if available.
      • Using the flat end of a spudger, loosen the connection between the back panel and the device. Remove the back panel using your hands.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung WB1100F Camera Flash Replacement, Camera Flash: adım 3, 3 resimden 1. Samsung WB1100F Camera Flash Replacement, Camera Flash: adım 3, 3 resimden 2. Samsung WB1100F Camera Flash Replacement, Camera Flash: adım 3, 3 resimden 3.
      • Remove four 1.2 mm Phillips #00 screws from the top panel.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung WB1100F Camera Flash Replacement: adım 4, 1 resimden 1.
      • Using the flat end of a spudger, loosen the connection between the top panel and the device. Remove the top panel using your hands.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung WB1100F Camera Flash Replacement: adım 5, 1 resimden 1.
      • Remove four 1.2 mm Phillips #00 screws from the flash assembly
      FixBot'a Sor
      Yorum Ekle
    4. Samsung WB1100F Camera Flash Replacement: adım 6, 1 resimden 1.
      • Using your hands, remove the flash assembly. This should not require much force.
      FixBot'a Sor
      Yorum Ekle
    5. Samsung WB1100F Camera Flash Replacement: adım 7, 2 resimden 1. Samsung WB1100F Camera Flash Replacement: adım 7, 2 resimden 2.
      • Using your hands, remove the top flash panel by pressuring down on the back to release a locking tab.
      FixBot'a Sor
      Yorum Ekle
    6. Samsung WB1100F Camera Flash Replacement: adım 8, 1 resimden 1.
      • Desolder three wires on the flash assembly.
      FixBot'a Sor
      Yorum Ekle
    7. Samsung WB1100F Camera Flash Replacement: adım 9, 1 resimden 1.
      • Gently remove the flash assembly from the body.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Jesse Lindsey
581 İtibar
5 adet Kılavuz yazıldı
Ekip
Metro State, Team 1-1, Carpenter SU 2016 Metro State, Team 1-1, Carpenter SU 2016 üyesi
MSU-CARPENTER-SU16S1G1
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 23
Her zaman: 944
