Ana içeriğe geç
Samsung WB150F Memory Card Replacement
  1. Samsung WB150F Memory Card Replacement, Memory Card: adım 1, 1 resimden 1.
    • Flip the camera upside-down so that the compartment with the battery and memory card is facing you.
  2. Samsung WB150F Memory Card Replacement: adım 2, 2 resimden 1. Samsung WB150F Memory Card Replacement: adım 2, 2 resimden 2.
    • Using your finger, slide the plastic lock-tab to the left.
    • The compartment should swing open.
    Memory card not support
    Bhabani Prasad Sardar - Yanıt
  3. Samsung WB150F Memory Card Replacement: adım 3, 1 resimden 1.
    • The larger cavity is for the battery.
    • The small thin cavity is where the memory card goes.
    • Press lightly on the memory card to eject it from the camera.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Keith Albergaria
202 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-4, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-4, Vijaybhaskar Spring 2015 üyesi
UMASSD-VIJAYBHASKAR-S15S4G4
3 Üyeler
6 adet Kılavuz yazıldı
2Kılavuz Yorumları
Will a micro cd n an adapter fit n the camera?
Maria Elena Will - Yanıt
I was looking for max size compatability. Most folks already know how to remove and install it.
bob kavanaugh - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 1,027
