Ana içeriğe geç
Samsung Watch Active Sensor Array Replacement
Neye ihtiyacın var
    1. Samsung Watch Active Sensor Array Replacement, Turn off the watch: adım 1, 2 resimden 1. Samsung Watch Active Sensor Array Replacement, Turn off the watch: adım 1, 2 resimden 2.
      • Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
      • When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Watch Active Sensor Array Replacement, Remove the rear screws: adım 2, 1 resimden 1.
      • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Watch Active Sensor Array Replacement, Separate the back cover from the housing: adım 3, 3 resimden 1. Samsung Watch Active Sensor Array Replacement, Separate the back cover from the housing: adım 3, 3 resimden 2. Samsung Watch Active Sensor Array Replacement, Separate the back cover from the housing: adım 3, 3 resimden 3.
      • Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
      • Push the tip of the opening tool into the gap to separate the back cover from the housing.
      • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung Watch Active Sensor Array Replacement, Disconnect the sensor array: adım 4, 2 resimden 1. Samsung Watch Active Sensor Array Replacement, Disconnect the sensor array: adım 4, 2 resimden 2.
      • Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
      • Use a spudger to disconnect the sensor array from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    5. Samsung Watch Active Sensor Array Replacement, Remove the back cover: adım 5, 1 resimden 1.
      • Remove the back cover.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Watch Active Sensor Array Replacement, Loosen the sensor array: adım 6, 3 resimden 1. Samsung Watch Active Sensor Array Replacement, Loosen the sensor array: adım 6, 3 resimden 2. Samsung Watch Active Sensor Array Replacement, Loosen the sensor array: adım 6, 3 resimden 3.
      • Use an opening pick and slide it underneath the sensor array which is slightly glued in place.
      • Carefully twist the opening pick to separate the sensor array from the back cover.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Watch Active Sensor Array Replacement, Remove the sensor array: adım 7, 2 resimden 1. Samsung Watch Active Sensor Array Replacement, Remove the sensor array: adım 7, 2 resimden 2.
      • Remove the sensor array from the back cover.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tobias Isakeit
134.915 İtibar
189 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 18
Son 30 gün: 67
Her zaman: 4,941
