Ana içeriğe geç
Samsung YP-P3 Buttons Replacement
Neye ihtiyacın var
  1. Samsung YP-P3 Buttons Replacement, Case Backplate: adım 1, 1 resimden 1.
    • Pry up the small black piece of plastic located between the volume [-] button and the HOLD/ON button.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung YP-P3 Buttons Replacement: adım 2, 1 resimden 1.
    • Underneath the piece of plastic you just removed, there is a small screw (Phillips #000, 2.0 mm long). Use a Phillips #000 screwdriver to remove it.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung YP-P3 Buttons Replacement: adım 3, 2 resimden 1. Samsung YP-P3 Buttons Replacement: adım 3, 2 resimden 2.
    • Push on the backplate with both thumbs, sliding it towards the top of the device.
    • Once it begins to move, lift up slightly. You can then slide the backplate all the way off.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung YP-P3 Buttons Replacement, Printed Circuit Board: adım 4, 3 resimden 1. Samsung YP-P3 Buttons Replacement, Printed Circuit Board: adım 4, 3 resimden 2. Samsung YP-P3 Buttons Replacement, Printed Circuit Board: adım 4, 3 resimden 3.
    • Before removing the circuit board, we must remove the ribbon-like wires attached to two sides of the circuit board.
    • There are two screws (Phillips #000, 2.0 mm long) holding in the circuit board. Use a Phillips #000 screwdriver to take out those screws.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung YP-P3 Buttons Replacement: adım 5, 2 resimden 1. Samsung YP-P3 Buttons Replacement: adım 5, 2 resimden 2.
    • The battery is also attached to the circuit board by a cable. The cable is difficult to disconnect with both components in place. It's best to lift the circuit board out partially to give yourself more room to disconnect the connector.
    • The wire that is connected to the circuit board is connected by a plastic piece with two metal prongs.
    • Use the pointy end of the spudger to place in between the computer board and the plastic piece and gently pry the prongs away from the circuit board.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung YP-P3 Buttons Replacement: adım 6, 1 resimden 1.
    • Disconnect the battery connector, and then lift the circuit board up.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung YP-P3 Buttons Replacement: adım 7, 1 resimden 1.
    • Finally, disconnect the ribbon cable on the bottom of the circuit board. You can then lift the circuit board all the way out.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung YP-P3 Buttons Replacement, Battery: adım 8, 1 resimden 1.
    • Use the spudger to carefully pry up the battery. The battery is attached with a few spots of glue, so it may not move at first.
    FixBot'a Sor
    Yorum Ekle
  9. Samsung YP-P3 Buttons Replacement, Touch Screen: adım 9, 3 resimden 1. Samsung YP-P3 Buttons Replacement, Touch Screen: adım 9, 3 resimden 2. Samsung YP-P3 Buttons Replacement, Touch Screen: adım 9, 3 resimden 3.
    • Remove the six screws (Phillips #000, 2.3 mm long) holding the screen frame to the front of the case. As the picture shows, one of them is hidden under the black speaker/rumble assembly.
    FixBot'a Sor
    Yorum Ekle
  10. Samsung YP-P3 Buttons Replacement: adım 10, 2 resimden 1. Samsung YP-P3 Buttons Replacement: adım 10, 2 resimden 2.
    • To access the screw under the black speaker rumble/assembly, you will need to pry the assembly up slightly using the spudger.
    • The assembly is glued to the back of the screen, so the assembly may not move at first. Be patient and careful. Do not pry too hard, or you may break the assembly.
    FixBot'a Sor
    Yorum Ekle
  11. Samsung YP-P3 Buttons Replacement: adım 11, 1 resimden 1.
    • Lift the screen out from the case.
    FixBot'a Sor
    Yorum Ekle
  12. Samsung YP-P3 Buttons Replacement, Buttons: adım 12, 2 resimden 1. Samsung YP-P3 Buttons Replacement, Buttons: adım 12, 2 resimden 2.
    • The buttons, built-in speaker, and rumble device are all contained in a black plastic assembly. This assembly simply snaps into place at the top of the case. Lift up gently to remove it from its place.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Andrew Groeneveld
585 İtibar
4 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 5-3, Lauer Spring 2014 Michigan Tech, Team 5-3, Lauer Spring 2014 üyesi
MTU-LAUER-S14S5G3
4 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
This is terrific, but who makes a 3”, 272x480 pixel lcd screen and/or touchpanel for the samsung? Is this the same screen hardware as on the P2?
Kevin Moorman - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 36
Her zaman: 1,061
