Ana içeriğe geç
Sapphire Nitro+ RX 6800 XT SE Fan Replacement
Neye ihtiyacın var
  1. Sapphire Nitro+ RX 6800 XT SE Fan Replacement, ARGB Fans: adım 1, 1 resimden 1.
    • Unscrew the JIS000 screw securing the fan to the graphics card
  2. Sapphire Nitro+ RX 6800 XT SE Fan Replacement: adım 2, 1 resimden 1.
    • Lift the fan from the top and pull away from you.
  3. Sapphire Nitro+ RX 6800 XT SE Fan Replacement: adım 3, 1 resimden 1.
    • Clean any dust or residue present with a Q-tip damp with alcohol.
  4. Sapphire Nitro+ RX 6800 XT SE Fan Replacement: adım 4, 1 resimden 1.
    • Flip the fan over and notice the pins on the fan and in the graphics card fan slot:
    • Fan Pins
    • Fan slot
    • Flip the fan back over keeping the same orientation and carfully insert the fan.
    • If inserted incorrectly the pins could bend or break!
  5. Sapphire Nitro+ RX 6800 XT SE Fan Replacement: adım 5, 1 resimden 1.
    • Push the fan toward you to ensure that the pins are connected.
  6. Sapphire Nitro+ RX 6800 XT SE Fan Replacement: adım 6, 1 resimden 1.
    • Rescrew the JIS000 screw in the top of the fan.
    • Repeat steps 1 - 5 on the remaining fans if needed.
    • The center fan has a unique fan sicker to designate it as the middle.
Sonuç
After assembly, the fans and RGB will work like new!
Bir başkası bu kılavuzu tamamladı.
Weston Wood
183 İtibar
1 Kılavuz yazıldı
Ekip
2Kılavuz Yorumları
What is the Screw used for this? I am having trouble finding a "3mm JIS 000" screw when I look it up. I accidentally dropped the screw somewhere in the pc when taking out the fan.
Ethan Callaway - Yanıt
Hello, I'm trying to find the screw too! Did you find it by any chance where to get replacement?
Waleed Almutairi -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 28
Son 30 gün: 179
Her zaman: 1,011
