Ana içeriğe geç
Seagate External Hard Drive drive replacement
Neye ihtiyacın var
  1. Seagate External Hard Drive drive replacement, Open the housing: adım 1, 2 resimden 1. Seagate External Hard Drive drive replacement, Open the housing: adım 1, 2 resimden 2.
    • It is best to open the case at the rear of the connectors.
    • The lid has plastic tabs (1) which are stuck in the base (2). They can be loosened by pushing the base outwzards with a flat screwdriver or similar tool.
    • The manufacturer did not intend for the case to be opened, so some damage to the case is to be expected. (3)
  2. Seagate External Hard Drive drive replacement, Remove the drive carriage: adım 2, 2 resimden 1. Seagate External Hard Drive drive replacement, Remove the drive carriage: adım 2, 2 resimden 2.
    • The hard disk can now be lifted out of the plastic housing. It is not attached any further.
  3. Seagate External Hard Drive drive replacement, Remove the drive from the drive carriage: adım 3, 3 resimden 1. Seagate External Hard Drive drive replacement, Remove the drive from the drive carriage: adım 3, 3 resimden 2. Seagate External Hard Drive drive replacement, Remove the drive from the drive carriage: adım 3, 3 resimden 3.
    • Unscrew the side screws.
    • Remove the permanently attached cables and stickers from the hard drive.
    • Then pull the hard drive backwards with a little force.
Sonuç
Repeat the steps in reverse order to reassemble your device.
2 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
de en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Nicola
61 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 20
Son 30 gün: 87
Her zaman: 1,910
