Ana içeriğe geç
Set-Top Box Numb Button Replacement
Neye ihtiyacın var
  1. Set-Top Box Numb Button Replacement, Numb Button: adım 1, 3 resimden 1. Set-Top Box Numb Button Replacement, Numb Button: adım 1, 3 resimden 2. Set-Top Box Numb Button Replacement, Numb Button: adım 1, 3 resimden 3.
    • Make sure the box is not plugged in before starting!
    • Remove the 5 screws holding the outer casing in place: 3 can be found on the back and 1 on either side of the box.
    • Slide the casing backwards.
    FixBot'a Sor
  2. Set-Top Box Numb Button Replacement: adım 2, 3 resimden 1. Set-Top Box Numb Button Replacement: adım 2, 3 resimden 2. Set-Top Box Numb Button Replacement: adım 2, 3 resimden 3.
    • Disconnect the front of the by lifting the 2 connectors . You can also apply extra pressure on the front from below.
    • Tilt the front forward and remove it.
    • Remove the connector by pressing the upper part of it and carefully pulling it.
    • Be carefull not to damage the cables and circuit board!
    FixBot'a Sor
  3. Set-Top Box Numb Button Replacement: adım 3, 3 resimden 1. Set-Top Box Numb Button Replacement: adım 3, 3 resimden 2. Set-Top Box Numb Button Replacement: adım 3, 3 resimden 3.
    • Undo the 4 screws of the front panel.
    • Locate your broken button. For instance, the third button from the left (front view), is the CH- button.
    FixBot'a Sor
  4. Set-Top Box Numb Button Replacement: adım 4, 3 resimden 1. Set-Top Box Numb Button Replacement: adım 4, 3 resimden 2. Set-Top Box Numb Button Replacement: adım 4, 3 resimden 3.
    • Unsolder the push button. You can push it out or maybe use some plyers.
    • Remove the old button and insert the new one.
    • Solder the new push button on.
    • Check this link for help How To Solder and Desolder Connections
    FixBot'a Sor
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 35
Her zaman: 699
