Ana içeriğe geç
Sew a Button
Neye ihtiyacın var
  1. Sew a Button, Sew a Button: adım 1, 1 resimden 1.
    • Locate the area where the button has gone missing.
    FixBot'a Sor
    Yorum Ekle
  2. Sew a Button: adım 2, 2 resimden 1. Sew a Button: adım 2, 2 resimden 2.
    • Overlap the buttonhole with where the button should be. Going through the buttonhole, mark the fabric below with tailor's chalk.
    FixBot'a Sor
    Yorum Ekle
  3. Sew a Button: adım 3, 2 resimden 1. Sew a Button: adım 3, 2 resimden 2.
    • Get a length of thread—about an arms-length should be more than enough.
    • Thread a needle.
    FixBot'a Sor
    Yorum Ekle
  4. Sew a Button: adım 4, 3 resimden 1. Sew a Button: adım 4, 3 resimden 2. Sew a Button: adım 4, 3 resimden 3.
    • Let the needle slide down the thread until it hangs at the center. You should have two equal lengths of thread on either side of the needle.
    • Tie the loose ends of the thread together.
    FixBot'a Sor
    Yorum Ekle
  5. Sew a Button: adım 5, 2 resimden 1. Sew a Button: adım 5, 2 resimden 2.
    • Tie a second regular knot over the first one to make it bigger. You don't want the thread slipping right through the grain of the fabric.
    FixBot'a Sor
    Yorum Ekle
  6. Sew a Button: adım 6, 3 resimden 1. Sew a Button: adım 6, 3 resimden 2. Sew a Button: adım 6, 3 resimden 3.
    • Poke the needle up through the chalk mark from the underside of the fabric.
    • Pull the thread taut, until the knot catches the backside of the fabric.
    FixBot'a Sor
    Yorum Ekle
  7. Sew a Button: adım 7, 2 resimden 1. Sew a Button: adım 7, 2 resimden 2.
    • Thread the needle through one hole of the button. You can pick any hole to start with.
    • Let the button drop all the way down onto the fabric.
    FixBot'a Sor
    Yorum Ekle
  8. Sew a Button: adım 8, 3 resimden 1. Sew a Button: adım 8, 3 resimden 2. Sew a Button: adım 8, 3 resimden 3.
    • Push the needle through the buttonhole directly opposite the one you have already threaded.
    • Be sure to go through only the button, not the fabric.
    FixBot'a Sor
    Yorum Ekle
  9. Sew a Button: adım 9, 3 resimden 1. Sew a Button: adım 9, 3 resimden 2. Sew a Button: adım 9, 3 resimden 3.
    • Push the needle back through the fabric directly next to where you initially pushed the needle up.
    • Pull the thread taut, until the button lays flat on the fabric.
    FixBot'a Sor
    Yorum Ekle
  10. Sew a Button: adım 10, 3 resimden 1. Sew a Button: adım 10, 3 resimden 2. Sew a Button: adım 10, 3 resimden 3.
    • Push the needle back up through the backside of the fabric, directly next to the original knot
    • Work the needle up through one of the two remaining holes without thread.
    • Pull the thread taut.
    FixBot'a Sor
    Yorum Ekle
  11. Sew a Button: adım 11, 3 resimden 1. Sew a Button: adım 11, 3 resimden 2. Sew a Button: adım 11, 3 resimden 3.
    • Go back through the last remaining empty hole on the button.
    • Go back down through the fabric, as close as possible to the other two threads.
    FixBot'a Sor
    Yorum Ekle
  12. Sew a Button: adım 12, 3 resimden 1. Sew a Button: adım 12, 3 resimden 2. Sew a Button: adım 12, 3 resimden 3.
    • Drive the needle back up through the underside of the fabric and into the first hole that you threaded.
    FixBot'a Sor
    Yorum Ekle
  13. Sew a Button: adım 13, 2 resimden 1. Sew a Button: adım 13, 2 resimden 2.
    • Go back down through the second hole, directly across from the hole you just came up through.
    • Pull taut.
    FixBot'a Sor
    Yorum Ekle
  14. Sew a Button: adım 14, 3 resimden 1. Sew a Button: adım 14, 3 resimden 2. Sew a Button: adım 14, 3 resimden 3.
    • Push the needle up through the third hole again.
    • Pull it taut.
    • Push the needle down through the fourth hole and pull it taut.
    • Repeat steps 12-14 of this guide one more time, then proceed.
    FixBot'a Sor
    Yorum Ekle
  15. Sew a Button: adım 15, 3 resimden 1. Sew a Button: adım 15, 3 resimden 2. Sew a Button: adım 15, 3 resimden 3.
    • You have sewn in the button. Now you need a knot to keep the button in place.
    • Push the needle through the loops of thread on the underside of the fabric. Be careful not to catch the fabric.
    FixBot'a Sor
    Yorum Ekle
  16. Sew a Button: adım 16, 2 resimden 1. Sew a Button: adım 16, 2 resimden 2.
    • Leave some slack in the thread and draw the needle through the loop created by the slack.
    • Pull the thread taut, forming a knot.
    • Repeat steps 15 and 16 one more time to add a second knot.
    FixBot'a Sor
    Yorum Ekle
  17. Sew a Button: adım 17, 2 resimden 1. Sew a Button: adım 17, 2 resimden 2.
    • Clip the excess thread off.
    • Check your button for stability.
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
64 farklı kişi bu kılavuzu tamamladı.
Brittany McCrigler
90.987 İtibar
142 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
31.535 adet Kılavuz yazıldı
5Kılavuz Yorumları
What helps after the last step 14 is to wrap the thread around and around a few times underneath the button itself (binding all the threads together) and making one last pass through the cloth before the final knot. This makes the repair much more durable.
mccreerydennis - Yanıt Paylaş
The wrapping below the button is not only more durable, but is actually frequently used when replacing buttons on blazers, sport coats, and the like as a protection from friction as the garment moves and shifts while being worn.
Matt - Yanıt Paylaş
Wrapping the threads underneath the button to create a shank is useful for coat buttons where the fabric is thick and you don’t want the fabric to pucker. As noted, it adds durability to the button attachment. On a shirt collar, as seen here, it would create too much bulk where you need the button to lie quite flat, so this method is quite sufficient.
Jonathan Wells - Yanıt Paylaş
Thanks Jonathan. Great insight.
Louie Leung - Yanıt Paylaş
Parfait, mon pantalon est comme neuf :)
Brendan - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 14
Son 7 gün: 108
Son 30 gün: 456
Her zaman: 24,684
