Ana içeriğe geç
Shark Cordless Pet Perfect Charging Port Replacement
Neye ihtiyacın var
  1. Shark Cordless Pet Perfect Charging Port Replacement, Charging Port: adım 1, 3 resimden 1. Shark Cordless Pet Perfect Charging Port Replacement, Charging Port: adım 1, 3 resimden 2. Shark Cordless Pet Perfect Charging Port Replacement, Charging Port: adım 1, 3 resimden 3.
    • Remove the dust cup container from the motor housing.
  2. Shark Cordless Pet Perfect Charging Port Replacement: adım 2, 3 resimden 1. Shark Cordless Pet Perfect Charging Port Replacement: adım 2, 3 resimden 2. Shark Cordless Pet Perfect Charging Port Replacement: adım 2, 3 resimden 3.
    • Remove the five 14mm screws with the PH 2 bit. Once all the screws are removed, pull one part of the housing away from the other.
  3. Shark Cordless Pet Perfect Charging Port Replacement: adım 3, 3 resimden 1. Shark Cordless Pet Perfect Charging Port Replacement: adım 3, 3 resimden 2. Shark Cordless Pet Perfect Charging Port Replacement: adım 3, 3 resimden 3.
    • Pull the charging port mount away from the housing. Once separated, pull the the charging port out of the mount to access the charging port itself.
  4. Shark Cordless Pet Perfect Charging Port Replacement: adım 4, 2 resimden 1. Shark Cordless Pet Perfect Charging Port Replacement: adım 4, 2 resimden 2.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Ashley Calkins
560 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-2, Blackwell Spring 2017 USF Tampa, Team 16-2, Blackwell Spring 2017 üyesi
USFT-BLACKWELL-S17S16G2
4 Üyeler
11 adet Kılavuz yazıldı
3 Yorum
yeah thanks buddy real helpful
James Melendez - Yanıt
not really though, any dunce can get this far. what part is used in the replacement? if replacing this part does not fix the problem, what are my alternatives? are there any tests i could run with a multimeter, say on the charger, battery, or any terminals? too light of an article in my opinion. anyone who can remove screws can get this far, where is there any electrical expertise involved? a real electrician would take a layman from start to finish, including tests to make sure replacing a part is worth the time and money, as in, will simply replacing the terminal actually fix the problem? we’ll find out the hard way. more advice needed in my opinion.
replacement part not listed is my main beef, to be honest, and a DMM test or two to be sure of the problem would be nice.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 3,857
