Ana içeriğe geç
Shark Flex DuoClean LED Headlight Replacement
Neye ihtiyacın var
  1. Shark Flex DuoClean LED Headlight Replacement, Garage Door: adım 1, 2 resimden 1. Shark Flex DuoClean LED Headlight Replacement, Garage Door: adım 1, 2 resimden 2.
    • Open the garage door by sliding both of the release buttons away from you.
    • Lift off the garage door.
    FixBot'a Sor
    Yorum Ekle
  2. Shark Flex DuoClean LED Headlight Replacement, Side Component: adım 2, 2 resimden 1. Shark Flex DuoClean LED Headlight Replacement, Side Component: adım 2, 2 resimden 2.
    • Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
    FixBot'a Sor
    Yorum Ekle
  3. Shark Flex DuoClean LED Headlight Replacement: adım 3, 2 resimden 1. Shark Flex DuoClean LED Headlight Replacement: adım 3, 2 resimden 2.
    • Turn the T10 Security Torx screwdriver counterclockwise to remove the 15mm screw.
    FixBot'a Sor
    Yorum Ekle
  4. Shark Flex DuoClean LED Headlight Replacement: adım 4, 1 resimden 1.
    • Use the iFixit Opening Tool to pry the side of the vacuum open.
    FixBot'a Sor
    Yorum Ekle
  5. Shark Flex DuoClean LED Headlight Replacement: adım 5, 1 resimden 1.
    • Remove the side component with your hands.
    FixBot'a Sor
    Yorum Ekle
  6. Shark Flex DuoClean LED Headlight Replacement, LED Headlight: adım 6, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  7. Shark Flex DuoClean LED Headlight Replacement: adım 7, 2 resimden 1. Shark Flex DuoClean LED Headlight Replacement: adım 7, 2 resimden 2.
    • Use the nylon spudger to pry the gold, plastic cover off of the headlights.
    • Prying off the cover too aggressively may cause it to break.
    FixBot'a Sor
    Yorum Ekle
  8. Shark Flex DuoClean LED Headlight Replacement: adım 8, 2 resimden 1. Shark Flex DuoClean LED Headlight Replacement: adım 8, 2 resimden 2.
    FixBot'a Sor
    Yorum Ekle
  9. Shark Flex DuoClean LED Headlight Replacement: adım 9, 2 resimden 1. Shark Flex DuoClean LED Headlight Replacement: adım 9, 2 resimden 2.
    • Use the metal spudger to pry off the clear, plastic cover on the LEDs.
    • Prying the cover off too aggressively may cause it to break.
    FixBot'a Sor
    Yorum Ekle
  10. Shark Flex DuoClean LED Headlight Replacement: adım 10, 1 resimden 1.
    • Use wire cutters to detach the black cables from the LEDs on both sides.
    • Strip 1 cm off the ends of the wires, using a wire stripper.
    • Solder the exposed wires to the new LEDs.
    • Use the soldering guide in the Introduction.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Samantha Mickelson
496 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G5, White Fall 2018 Cal Poly, Team S17-G5, White Fall 2018 üyesi
CPSU-WHITE-F18S17G5
4 Üyeler
25 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 23
Her zaman: 1,832
