Ana içeriğe geç
Shark ION Robot 750 Battery Replacement
Neye ihtiyacın var
  1. Shark ION Robot 750 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the device is completely powered off before working.
    • On the bottom of the vacuum, unscrew both sides of the vacuum cover using a Phillips screwdriver.
    • Gently lift and remove the cover.
  2. Shark ION Robot 750 Battery Replacement: adım 2, 2 resimden 1. Shark ION Robot 750 Battery Replacement: adım 2, 2 resimden 2.
    • Grip both of the battery pull tabs and lift the battery out.
    • Be careful when lifting the battery out because it is still connected to the motherboard.
  3. Shark ION Robot 750 Battery Replacement: adım 3, 2 resimden 1. Shark ION Robot 750 Battery Replacement: adım 3, 2 resimden 2.
    • To disconnect the battery, firmly squeeze down on the marked tabs, then pull the connector out of the socket.
Bitiş Çizgisi
Tuong Tran
196 İtibar
2 adet Kılavuz yazıldı
1Rehber Yorum
Does the new battery need charging once inserted and if so how long? Mine did nothing once inserted. It didn't even light up!
Donna Ray-Reifler - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 15
Her zaman: 201
