Ana içeriğe geç
Shark ION Robot 750 Button Panel Replacement
Neye ihtiyacın var
  1. Shark ION Robot 750 Button Panel Replacement, Button Panel: adım 1, 2 resimden 1. Shark ION Robot 750 Button Panel Replacement, Button Panel: adım 1, 2 resimden 2.
    • Before you begin, make sure the vacuum is off.
    • Use a spudger to remove the top case of the vacuum.
    • Flip over the top case.
    • Use tweezers or your hands to remove the center button panel from the socket.
  2. Shark ION Robot 750 Button Panel Replacement: adım 2, 2 resimden 1. Shark ION Robot 750 Button Panel Replacement: adım 2, 2 resimden 2.
    • Use your hands or tweezers to remove the other button panel from its socket.
    • Use a spudger to pop the panel off of the connector if you need help.
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Ashley Nguyen
85 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 128
