Ana içeriğe geç
Shark ION Robot 750 Front Caster Wheel Replacement
Olivia Jones
Olivia Jones ve başka bir katkıda bulunan
En son June 21, 2024 tarihinde güncellendi
30 saniye - 1 dakika
Çok kolay
This guide focuses on the front pivot or caster wheel replacement process on the Shark ION Robot 750. The front caster wheel allows the vacuum to move across the floor and change directions. You may need to replace this part if you notice your robot skidding along the floor, making unusual sounds, or showing visible damage.
Before you begin this repair, make sure that your device is turned off.
Neye ihtiyacın var
  1. Shark ION Robot 750 Front Caster Wheel Replacement, Front Caster Wheel: adım 1, 1 resimden 1.
    • Grab the base of the front pivot wheel.
  2. Shark ION Robot 750 Front Caster Wheel Replacement: adım 2, 1 resimden 1.
    • Pull the front pivot wheel out of the base.
    • Before you replace the front caster wheel, be sure to remove debris or dust that may have built up in the space. Use a dry clothe to wipe the sensors in the cavity clean.
  3. Shark ION Robot 750 Front Caster Wheel Replacement: adım 3, 1 resimden 1.
    • Remove the sensor wheel from the caster assembly.
Sonuç
Olivia Jones
97 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 63
