Ana içeriğe geç
Shark ION Robot S87 Drive Wheel Replacement
Neye ihtiyacın var
  1. Shark ION Robot S87 Drive Wheel Replacement, Drive Wheel: adım 1, 2 resimden 1. Shark ION Robot S87 Drive Wheel Replacement, Drive Wheel: adım 1, 2 resimden 2.
    • Make sure device is turned off before attempting this replacement.
    • Remove three 13mm screws using a T15 Torx screwdriver.
    • Remove one 15mm screw using a Phillips #1 screwdriver.
    • Remove one final 15mm Phillips #1 screw.
  2. Shark ION Robot S87 Drive Wheel Replacement: adım 2, 1 resimden 1.
    • Carefully lift the wheel assembly out of the housing, making sure not to damage its connecting wire.
  3. Shark ION Robot S87 Drive Wheel Replacement: adım 3, 1 resimden 1.
    • Disconnect the wire carefully from the wheel assembly by pinching and pulling away from it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Trevor Davies
297 İtibar
2 adet Kılavuz yazıldı
Ekip
2Kılavuz Yorumları
Dude you made my day. Cost me 14 bucks for a torx set and fixed my little cleaning buddy. All it needed was to be blown out with compressed air and plugged back in. THANK YOU!!!
DovieAndiSeTova - Yanıt Paylaş
Where can we get the replacement wheel and motor?
Shelly G Petty - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 20
Son 30 gün: 55
Her zaman: 2,522
