Ana içeriğe geç
Sharper Image iPulse SI325 DC Input Replacement
Neye ihtiyacın var
  1. Sharper Image iPulse SI325 DC Input Replacement, Outer Case: adım 1, 2 resimden 1. Sharper Image iPulse SI325 DC Input Replacement, Outer Case: adım 1, 2 resimden 2.
    • Gently position the device so that the buttons and speakers lie face down.
    • Unplug the power cord from the "DC Input."
    FixBot'a Sor
    Yorum Ekle
  2. Sharper Image iPulse SI325 DC Input Replacement: adım 2, 3 resimden 1. Sharper Image iPulse SI325 DC Input Replacement: adım 2, 3 resimden 2. Sharper Image iPulse SI325 DC Input Replacement: adım 2, 3 resimden 3.
    • Remove the four 12mm phillips head #2 screws located along the outer edge of the white case.
    • Be careful! There are two small, easily-broken, plastic tabs at the bottom of the device keeping it together.
    • Once you remove the screws, pick the device up so that the grey label on the bottom of the device faces toward you.
    • With your thumbs on either side of the grey label, slowly push with both thumbs until the case pops open.
    • A small gap will open as the two tabs are released.
    • Do not pull the two halves apart yet. They are held together by the speaker wire.
    FixBot'a Sor
    Yorum Ekle
  3. Sharper Image iPulse SI325 DC Input Replacement: adım 3, 2 resimden 1. Sharper Image iPulse SI325 DC Input Replacement: adım 3, 2 resimden 2.
    • Grip both sides of the top round part of the case and carefully open it like a clam. The bottom of the two halves are connected by the speaker wire. Do not separate by more than 1 centimeter.
    • Grip either side of the top round part of the case and carefully open the device to reveal all the hidden treasures inside!
    • Lay the device down, so that all the internal components are facing upwards.
    FixBot'a Sor
    Yorum Ekle
  4. Sharper Image iPulse SI325 DC Input Replacement, Auxiliary Input: adım 4, 1 resimden 1.
    • Turn the device over so that the internals are facing down; the Light Intensity Dial will be facing you.
    • Remove the three 7mm Phillips #1 screws connecting the Zipconnect unit.
    FixBot'a Sor
    Yorum Ekle
  5. Sharper Image iPulse SI325 DC Input Replacement: adım 5, 2 resimden 1. Sharper Image iPulse SI325 DC Input Replacement: adım 5, 2 resimden 2.
    • Turn the device over again so you are looking at the internals.
    • The Zipconnect unit will lift out but will still be attached by a wire connected to the motherboard.
    • Remove the six 7mm Phillips #1 screws attaching the Zipconnect unit to the motherboard wire and set the unit out of the way.
    FixBot'a Sor
    Yorum Ekle
  6. Sharper Image iPulse SI325 DC Input Replacement: adım 6, 2 resimden 1. Sharper Image iPulse SI325 DC Input Replacement: adım 6, 2 resimden 2.
    • Next, disconnect the speaker wire from the motherboard by gripping the wires as close to the connection as possible and pulling the connector out.
    • Moving the connector back and forth as you pull will make removal easier.
    FixBot'a Sor
    Yorum Ekle
  7. Sharper Image iPulse SI325 DC Input Replacement: adım 7, 1 resimden 1.
    • Remove the two 11mm Phillips #1 screws attaching the small brown circuit board to the plastic case.
    • Also remove the four 11mm Phillips #1 screws attaching the motherboard to the plastic case.
    FixBot'a Sor
    Yorum Ekle
  8. Sharper Image iPulse SI325 DC Input Replacement: adım 8, 3 resimden 1. Sharper Image iPulse SI325 DC Input Replacement: adım 8, 3 resimden 2. Sharper Image iPulse SI325 DC Input Replacement: adım 8, 3 resimden 3.
    • Lift up on the motherboard and light intensity dial circuit board to expose the circuit board containing the auxiliary input, sub input, and DC input.
    • Remove the two 7mm Phillips #1 screws attaching the brown circuit board with all of the inputs.
    FixBot'a Sor
    Yorum Ekle
  9. Sharper Image iPulse SI325 DC Input Replacement: adım 9, 2 resimden 1. Sharper Image iPulse SI325 DC Input Replacement: adım 9, 2 resimden 2.
    • Lift up the circuit board containing the Auxillary, DC, and sub inputs and move the lower case out of the way.
    • Turn the circuit board over so the solder is visible. Depending on which input is broken remove the solder connecting either the Auxillary, DC, or Sub input.
    • DC input
    • Auxillary Input
    • Sub Input
    FixBot'a Sor
    Yorum Ekle
Sonuç
Melissa Pasa
701 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 11-33, Amido Fall 2013 Cal Poly, Team 11-33, Amido Fall 2013 üyesi
CPSU-AMIDO-F13S11G33
4 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 799
