Ana içeriğe geç
Shure SM58 XLR Connector Wire Repair
Neye ihtiyacın var
  1. Shure SM58 XLR Connector Wire Repair, XLR Microphone Connector Disassembly: adım 1, 1 resimden 1.
    • Using a small flat head screwdriver, gently turn the retaining screw at the bottom of the microphone counterclockwise until it stops or provides resistance.
    • The retaining screw is mounted to the connector and has a left-handed thread. Turning the screw clockwise locks the connector in place. Turning it counterclockwise lowers it down into the hole, releasing the connector.
    • Once the screw stops, do not try to loosen it further.
  2. Shure SM58 XLR Connector Wire Repair: adım 2, 1 resimden 1.
    • Plug an XLR cable into the loose connector.
    • While holding the disconnect button down, pull on the cable to remove the connector from the body of the microphone.
  3. Shure SM58 XLR Connector Wire Repair, Shure SM58 XLR Connector Wire Repair: adım 3, 1 resimden 1.
    • If the wire is not exposed from the insulation, strip the broken wire.
  4. Shure SM58 XLR Connector Wire Repair: adım 4, 1 resimden 1.
    • Bend the wire around the contact point. Pin numbers are located on the outside of the connector.
    • Connect the red wire to Pin 3 and the blue wire to Pin 2.
    • Pin 1 should have a single piece of exposed wire connecting it to the metal plate on the top of the connector (the ground plate).
  5. Shure SM58 XLR Connector Wire Repair: adım 5, 1 resimden 1.
    • Clamps are helpful for this step.
    • In one hand, hold the solder. In the other, hold your soldering iron.
    • Touch both the soldering iron and the solder to the contact point. The solder should melt and create a connection between the wire and the microphone connector.
  6. Shure SM58 XLR Connector Wire Repair: adım 6, 1 resimden 1.
    • Remove the solder and then the soldering iron from the contact point.
    • If you remove the soldering iron first, the solder may become stuck to the contact point.
    • Let the wire cool for 30 seconds or so.
    • If the wire is not completely connected repeat steps 2 through 5.
  7. Shure SM58 XLR Connector Wire Repair: adım 7, 1 resimden 1.
Sonuç
After soldering the wires to the XLR connector and reassembling your microphone, your microphone should be ready to plug in to the XLR cable and function properly.
4 farklı kişi bu kılavuzu tamamladı.
nat coll
850 İtibar
14 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-53, Forte Fall 2012 Cal Poly, Team 7-53, Forte Fall 2012 üyesi
CPSU-FORTE-F12S7G53
5 Üyeler
33 adet Kılavuz yazıldı
9Kılavuz Yorumları
Many thanks. Very helpful.
Namron - Yanıt Paylaş
Yes I'm glad it was so simple and quick to fix my mic!
heyaly - Yanıt Paylaş
Red wire to pin 3? Seems to go against the pin 2 hot method?
Jim - Yanıt Paylaş
I'm not familiar with the "pin 2 hot method." We took a working mic apart and reassembled it the way we found it, so I'm pretty that is the correct soldering configuration.
Daniel Berger - Paylaş
Świetna strona. Brawo.
Kazimierz Serafin - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 37
Son 30 gün: 146
Her zaman: 31,724
