Ana içeriğe geç
Skateboard Trucks Replacement
Neye ihtiyacın var
  1. Skateboard Trucks Replacement, Trucks: adım 1, 2 resimden 1. Skateboard Trucks Replacement, Trucks: adım 1, 2 resimden 2.
    • Insert bolt hardware through the factory drilled holes from the top side of the skateboard.
    • If you have a riser and would like to install it, please reference the Wheel Bite Prevention guide.
  2. Skateboard Trucks Replacement: adım 2, 1 resimden 1.
    • Slide the truck onto the four protruding bolt hardware screws, while using your hand to prevent the screws from popping out the top of the skateboard.
  3. Skateboard Trucks Replacement: adım 3, 1 resimden 1.
    • Hand tighten the nut hardware onto all four bolts.
  4. Skateboard Trucks Replacement: adım 4, 1 resimden 1.
    • While holding the nuts on the bottom side of the skateboard in place with the 3/8" wrench, tighten the screws from the top side of the skateboard with a screwdriver. Tighten the screws in a diagonal pattern until the head of the screw sinks slightly into the grip tape.
    • Repeat steps 1 - 6 to install the second truck.
Sonuç
To uninstall your trucks, simply follow these steps in reverse order. To continue assembling your skateboard deck, see the Wheel Installation guide.
2 farklı kişi bu kılavuzu tamamladı.
Cameron Nye
79 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 6-32, Regan Fall 2012 Cal Poly, Team 6-32, Regan Fall 2012 üyesi
CPSU-REGAN-F12S6G32
5 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 19
Her zaman: 13,586
