Ana içeriğe geç
Skullcandy UPROCK Earpiece Wiring Replacement
Neye ihtiyacın var
  1. Skullcandy UPROCK Earpiece Wiring Replacement, Earpiece Wiring: adım 1, 1 resimden 1.
    • Remove the cushion from the ear piece.
  2. Skullcandy UPROCK Earpiece Wiring Replacement: adım 2, 2 resimden 1. Skullcandy UPROCK Earpiece Wiring Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #0 to unscrew three 3.4MM screws from the earpiece.
  3. Skullcandy UPROCK Earpiece Wiring Replacement: adım 3, 2 resimden 1. Skullcandy UPROCK Earpiece Wiring Replacement: adım 3, 2 resimden 2.
    • Find the wires connected to the speaker and check if they are intact.
  4. Skullcandy UPROCK Earpiece Wiring Replacement: adım 4, 1 resimden 1.
    • If a wire is broken, use a soldering iron to reattach it to the speaker.
    • To learn how to solder, read the How To Solder and Desolder Connections Guide.
    • After soldering is complete, the wires should look like this.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
Kayla Robinson
260 İtibar
2 adet Kılavuz yazıldı
Bir Yorum
my jack is broken can i get a whole new wire so i could do soldering or can i use any other wire. if i use any other wire can i connect in btw of old wire coz i removed the jack by cutting the wire from jack or do i have to do soldering from beginning form inside.
Anuj Verma - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 14
Her zaman: 6,203
