Ana içeriğe geç
Skytex SP728 Antenna Replacement
Galika Adhikari
Galika Adhikari ve 3 diğer katkıda bulunanlar
En son May 7, 2019 tarihinde güncellendi
10 - 15 dakika
Orta
İşlem Görüntüleri
This repair guide will walk through the primary steps of replacing the antenna in Skytex SP728.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Skytex SP728 Antenna Replacement, Case: adım 1, 1 resimden 1.
    • Make sure the device is powered off
    • Rotate the device so the ports and screws face you
  2. Skytex SP728 Antenna Replacement: adım 2, 1 resimden 1.
    • Using a small phillips screwdriver, unscrew both end screws
  3. Skytex SP728 Antenna Replacement: adım 3, 1 resimden 1.
    • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
  4. Skytex SP728 Antenna Replacement: adım 4, 1 resimden 1.
    • Once the case has been loosened, pry the backing off gently with your hands.
    • Make sure to remove the case gently as extra force can break the clasps or the case itself.
  5. Skytex SP728 Antenna Replacement, Antenna: adım 5, 1 resimden 1.
    • Remove the case and open the device
  6. Skytex SP728 Antenna Replacement: adım 6, 1 resimden 1.
    • Remove the black tapes
  7. Skytex SP728 Antenna Replacement: adım 7, 1 resimden 1.
    • Use the soldering station and remove soldered connections to the antenna wires.
    • Now replace the antenna.
    • Follow the link below for additional soldering information "https://www.ifixit.com/Guide/How+To+Sold...
Sonuç
Bir başkası bu kılavuzu tamamladı.
Galika Adhikari
248 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-1, Brown Winter 2015 USF Tampa, Team 5-1, Brown Winter 2015 üyesi
USFT-BROWN-W15S5G1
4 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 119
