Ana içeriğe geç
Skytex Skypad Alpha 2 Battery Replacement
Neye ihtiyacın var
  1. Skytex Skypad Alpha 2 Battery Replacement, Back Cover: adım 1, 1 resimden 1.
    • Power off the tablet.
    • Unplug the tablet from the power source if it is connected.
  2. Skytex Skypad Alpha 2 Battery Replacement: adım 2, 2 resimden 1. Skytex Skypad Alpha 2 Battery Replacement: adım 2, 2 resimden 2.
    • Remove the (4) 3.5mm screws using a phillips #000 screwdriver.
  3. Skytex Skypad Alpha 2 Battery Replacement: adım 3, 1 resimden 1.
    • Use the plastic opening tool to work your way around the tablet, releasing the back case from the tabs.
  4. Skytex Skypad Alpha 2 Battery Replacement: adım 4, 1 resimden 1.
    • Release the back case from the rest of the tablet with your hand.
    • Do not pry the case too hard; doing so can damage the tablet.
  5. Skytex Skypad Alpha 2 Battery Replacement, Battery: adım 5, 1 resimden 1.
    • Remove soldered connections to separate the battery wires from the motherboard.
    • Remove all black and yellow tape, if necessary, on motherboard.
    • Following the red and black wires, that come out of the battery, to their respective connections on the motherboard will indicate where to solder.
    • Follow link for further soldering information: How to Solder and Desolder Connections
  6. Skytex Skypad Alpha 2 Battery Replacement: adım 6, 1 resimden 1.
    • Use the plastic opening tool to remove battery from tablet.
    • Be sure to remove the battery carefully to avoid damage. Damage of battery can release harmful chemicals and may cause a fire.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Rebecca Ramirez
481 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team 6-5, Williams Fall 2015 Baylor, Team 6-5, Williams Fall 2015 üyesi
BU-WILLIAMS-F15S6G5
3 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
Excellent Guide
Problem is where to obtain the Replacement battery ???
J P SULLIVAN - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 863
