Ana içeriğe geç
Slingbox 500 Top Cover Replacement
David Sullivan
David Sullivan ve başka bir katkıda bulunan
En son December 30, 2021 tarihinde güncellendi
5 dakika
Kolay
Daha iyi giriş
Neye ihtiyacın var
Aletler
  1. Slingbox 500 Top Cover Replacement, Top Cover: adım 1, 1 resimden 1.
    • Remove the sticker on the back of the Slingbox that covers the rear screws using a spudger.
  2. Slingbox 500 Top Cover Replacement: adım 2, 2 resimden 1. Slingbox 500 Top Cover Replacement: adım 2, 2 resimden 2.
    • Remove the seven 7.9 mm rear screws from the device using a Phillips #1 screwdriver.
    • Flip your Slingbox so the bottom is facing upwards.
    • Remove the four 7.9 mm screws using a Phillips #1 screwdriver.
    • You may have rubber feet on the bottom of your Slingbox. If you do, just gently remove them with your hands and set them aside to put back on later.
  3. Slingbox 500 Top Cover Replacement: adım 3, 3 resimden 1. Slingbox 500 Top Cover Replacement: adım 3, 3 resimden 2. Slingbox 500 Top Cover Replacement: adım 3, 3 resimden 3.
    • Remove the upper section of the case by rotating your Slingbox to view the back and lifting up on the higher corner.
    • Use the opening tool to disconnect the small clips in the front.
    • These may require some minor force to disconnect.
    • Remove the entire top of the Slingbox and set it aside.
Sonuç
David Sullivan
365 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-3, Simcock Fall 2021 UMass Dartmouth, Team 1-3, Simcock Fall 2021 üyesi
UMASSD-SIMCOCK-F21S1G3
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 8
Her zaman: 94
