Ana içeriğe geç
Smart Parts Ion Eyes Replacement
Shane Villalpando
Shane Villalpando ve 3 diğer katkıda bulunanlar
En son June 19, 2015 tarihinde güncellendi
10 - 25 dakika
Kolay
Sometimes the Ion's eye vision board is damaged and may need replacing. While working on the Ion, the user should be aware of the pressure due to air inside the gun. Pressurized air can be forceful, causing particles to be ejected from the gun into your eyes and/or skin. When air bubbles enter the bloodstream, they can block blood vessels and cause embolisms. To avoid this, make sure to point the gun in a safe direction when de-gasing the Ion.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Smart Parts Ion Eyes Replacement, Hopper and the Air Tank: adım 1, 3 resimden 1. Smart Parts Ion Eyes Replacement, Hopper and the Air Tank: adım 1, 3 resimden 2. Smart Parts Ion Eyes Replacement, Hopper and the Air Tank: adım 1, 3 resimden 3.
    • Remove the air tank by rotating it counterclockwise.
    • Do not pull the trigger or jostle the gun, there will still be pressurized air inside the gun that could be expelled and cause bodily harm if injected into eyes and/or skin.
    • The pressure gauge will indicate the leftover air in the gun.
  2. Smart Parts Ion Eyes Replacement: adım 2, 2 resimden 1. Smart Parts Ion Eyes Replacement: adım 2, 2 resimden 2.
    • Remove the hopper by pulling it out of the feed tube, located on the top of the body. The hopper should easily come off when pulled straight up.
  3. Smart Parts Ion Eyes Replacement, Smart Parts Ion De-Gassing: adım 3, 1 resimden 1.
    • Turn the gun on by pressing the power button until the red light blinks.
    • Turn vision mode off by pressing the power button again.
    • Red light should be flashing in a double blink sequence.
  4. Smart Parts Ion Eyes Replacement: adım 4, 1 resimden 1.
    • Pull the trigger to release the air in the gun.
    • Pressurized air can be forceful, causing particles to be ejected from the gun into your eyes and/or skin. When air bubbles enter the bloodstream, they can block blood vessels, causing embolisms. To avoid this, make sure to point the gun in a safe direction when pulling the trigger because air will be released from the gun.
  5. Smart Parts Ion Eyes Replacement, Grip: adım 5, 1 resimden 1.
    • Remove the four 8mm screws on each side of the gun's grip using a Phillips #2 screwdriver.
  6. Smart Parts Ion Eyes Replacement: adım 6, 1 resimden 1.
    • Remove the grip by sliding it towards the front of the gun.
  7. Smart Parts Ion Eyes Replacement, Battery: adım 7, 2 resimden 1. Smart Parts Ion Eyes Replacement, Battery: adım 7, 2 resimden 2.
    • Remove the 9V battery by unsnapping it.
  8. Smart Parts Ion Eyes Replacement, Separate Body From Grip Frame: adım 8, 3 resimden 1. Smart Parts Ion Eyes Replacement, Separate Body From Grip Frame: adım 8, 3 resimden 2. Smart Parts Ion Eyes Replacement, Separate Body From Grip Frame: adım 8, 3 resimden 3.
    • Remove the front and rear 1" screws on the gun's grip frame using a 3/32" Allen Wrench.
  9. Smart Parts Ion Eyes Replacement: adım 9, 2 resimden 1. Smart Parts Ion Eyes Replacement: adım 9, 2 resimden 2.
    • Remove the 12 mm screw on the top of the grip frame using a 3/32" Allen wrench.
  10. Smart Parts Ion Eyes Replacement: adım 10, 1 resimden 1.
    • Separate the gun's body from the frame by gently pulling them in opposite directions.
  11. Smart Parts Ion Eyes Replacement: adım 11, 1 resimden 1.
    • Remove the 1-1/4" screw that's attached to the blue tube above the front grip using a 3/32" Allen Wrench.
  12. Smart Parts Ion Eyes Replacement, Eyes: adım 12, 2 resimden 1. Smart Parts Ion Eyes Replacement, Eyes: adım 12, 2 resimden 2.
    • Remove the gun's green vision eye board by gently pulling it out using your index finger and thumb.
Sonuç
Shane Villalpando
1.031 İtibar
10 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-42, Amido Winter 2015 Cal Poly, Team 8-42, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S8G42
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 1,456
