Giriş
Follow this guide to replace or change the Quick-Swap Soldering Tip in your FixHub Smart Soldering Iron.
See our store for available soldering iron tips.
Neye ihtiyacın var
Blue LED: The iron has cooled below 40 °C (100 °F), and the tip is safe to touch.
Purple LED: When pulsing, the iron is actively heating up or cooling down. When static, the iron is in Idle Mode. The iron tip is not safe to touch.
Orange LED: The iron has reached the set temperature and is ready to solder. The iron tip is not safe to touch.
Orange: ON
Blue: OFF
Slide the power switch to the blue OFF position.
Leave the soldering iron connected until the indicator ring turns blue, indicating it's now safe to touch the soldering iron tip.
Twist the blue cable collar counter-clockwise and pull up to release it from the iron.
Disconnect the USB-C cable from the Smart Soldering Iron.
Hold the iron from both ends and pull to remove the cap.
Firmly grasp the base of the tip and pull it away from the front of the iron handle to remove it.
Push the tip into the iron enclosure in the handle until it clicks into place.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Answers community for help.
