Ana içeriğe geç
Solio CLASSIC2 LED Light Replacement
Neye ihtiyacın var
  1. Solio CLASSIC2 LED Light Replacement, Disconnecting the Battery: adım 1, 1 resimden 1.
    • Turn off the device by pressing on the clear power button behind the device.
    • To make sure that it is off, make sure the button is not flashing green.
    FixBot'a Sor
    Yorum Ekle
  2. Solio CLASSIC2 LED Light Replacement: adım 2, 1 resimden 1.
    • Using the Phillips #1 screwdriver, remove the 2mm screw located on the bottom of the device, near the hinge.
    FixBot'a Sor
    Yorum Ekle
  3. Solio CLASSIC2 LED Light Replacement: adım 3, 3 resimden 1. Solio CLASSIC2 LED Light Replacement: adım 3, 3 resimden 2. Solio CLASSIC2 LED Light Replacement: adım 3, 3 resimden 3.
    • Using the plastic opening tools, gently pry open the side of the large panel.
    • Keeping the tool in, slowly slide the tool along the side of the panel.
    FixBot'a Sor
    Yorum Ekle
  4. Solio CLASSIC2 LED Light Replacement: adım 4, 2 resimden 1. Solio CLASSIC2 LED Light Replacement: adım 4, 2 resimden 2.
    • Rotate the device 180 degrees.
    • Make sure the opening on other side of the device does not snap closed.
    • Gently slide the plastic opening tool along the side of the panel.
    FixBot'a Sor
    Yorum Ekle
  5. Solio CLASSIC2 LED Light Replacement: adım 5, 2 resimden 1. Solio CLASSIC2 LED Light Replacement: adım 5, 2 resimden 2.
    • Do not fully pull apart the back panel from the device. Doing so can rip the two red and blue wires attached to the panel.
    • Using both hands, slowly pull apart the back panel from the rest of the device.
    • Gently flip the back panel open so the circuit board faces up and the two panels are side by side.
    FixBot'a Sor
    Yorum Ekle
  6. Solio CLASSIC2 LED Light Replacement: adım 6, 2 resimden 1. Solio CLASSIC2 LED Light Replacement: adım 6, 2 resimden 2.
    • Softly pinch the red and blue wires close to the white connector.
    • To pull the wires out, wiggle them back and forth until the connector is fully out.
    FixBot'a Sor
    Yorum Ekle
  7. Solio CLASSIC2 LED Light Replacement, Circuit Board: adım 7, 1 resimden 1.
    • Unscrew the three 2mm screws holding the circuit board down using a Phillips #1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  8. Solio CLASSIC2 LED Light Replacement: adım 8, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Make sure the white USB port cover on the side of the device is pulled out or you won't be able to lift the circuit board.
    • Gently lift the circuit board out of the device using tweezers.
    FixBot'a Sor
    Yorum Ekle
  9. Solio CLASSIC2 LED Light Replacement, LED Light: adım 9, 1 resimden 1.
    • Soldering can melt key components and cause harm to both the user and the device. Read soldering guide before attemptingDesolder the LED lights.
    • Desolder the LED lights.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Eric Padilla
201 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-28, Amido Fall 2013 Cal Poly, Team 4-28, Amido Fall 2013 üyesi
CPSU-AMIDO-F13S4G28
4 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 602
