Ana içeriğe geç
Solio Rocsta Charging Cable Replacement
Neye ihtiyacın var
  1. Solio Rocsta Charging Cable Replacement, Charging Cable: adım 1, 2 resimden 1. Solio Rocsta Charging Cable Replacement, Charging Cable: adım 1, 2 resimden 2.
    • Locate, and unscrew, the three 5.72 mm screws that hold down the top cover using the T6 Torx screwdriver.
  2. Solio Rocsta Charging Cable Replacement: adım 2, 2 resimden 1. Solio Rocsta Charging Cable Replacement: adım 2, 2 resimden 2.
    • Remove top cover.
    • Caution: the solar cell is attached to the top cover and connected to the circuit board by a short wire.
  3. Solio Rocsta Charging Cable Replacement: adım 3, 1 resimden 1.
    • Using the spudger, pry the battery off the back cover.
  4. Solio Rocsta Charging Cable Replacement: adım 4, 1 resimden 1.
    • Unscrew the 5.66 mm screws attaching the circuit board to the case.
  5. Solio Rocsta Charging Cable Replacement: adım 5, 1 resimden 1.
    • With the circuit board flipped, locate the battery connector.
    • Hold the component attached to the circuit board the battery is connected to and wiggle the cable out.
  6. Solio Rocsta Charging Cable Replacement: adım 6, 1 resimden 1.
    • With a Soldering Iron, desolder the four cables that connect the charging cable to the circuit board.
    • The power cable is a series of four cables. Make note of each cable placement for easy resoldering.
    • For more information on how to solder and desolder connections, please visit this guide.
Sonuç
David Vazquez
577 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S13-G13, Cagle Fall 2017 USF Tampa, Team S13-G13, Cagle Fall 2017 üyesi
USFT-CAGLE-F17S13G13
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 292
