Ana içeriğe geç
Solio Rocsta LED Replacement
Neye ihtiyacın var
  1. Solio Rocsta LED Replacement, Solio Rocsta Top Cover Disassembly: adım 1, 2 resimden 1. Solio Rocsta LED Replacement, Solio Rocsta Top Cover Disassembly: adım 1, 2 resimden 2.
    • Locate, and unscrew, the three 5.72 mm screws that hold down the top cover using the T6 Torx screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Solio Rocsta LED Replacement: adım 2, 2 resimden 1. Solio Rocsta LED Replacement: adım 2, 2 resimden 2.
    • Remove top cover.
    • Caution: the solar cell is attached to the top cover and connected to the circuit board by a short wire .
    FixBot'a Sor
    Yorum Ekle
  3. Solio Rocsta LED Replacement, Battery: adım 3, 1 resimden 1.
    • Using the spudger, pry the battery off the back cover.
    FixBot'a Sor
    Yorum Ekle
  4. Solio Rocsta LED Replacement: adım 4, 1 resimden 1.
    • Using a T6 Torx screwdriver, unscrew the 5.66 mm screws attaching the circuit board to the case and flip the circuit board.
    FixBot'a Sor
    Yorum Ekle
  5. Solio Rocsta LED Replacement: adım 5, 1 resimden 1.
    • With the circuit board flipped, locate the battery connector.
    • Hold the component attached to the circuit board the battery is connected to and wiggle the cable out.
    FixBot'a Sor
    Yorum Ekle
  6. Solio Rocsta LED Replacement, LED: adım 6, 1 resimden 1.
    • Using a T6 Torx screwdriver, unscrew the 5.66 mm screws attaching the circuit board to the case.
    FixBot'a Sor
    Yorum Ekle
  7. Solio Rocsta LED Replacement: adım 7, 1 resimden 1.
    • Flip the circuit board to be able to see where the LEDs are soldered to.
    • With a Soldering Iron, desolder the LEDs’ connectors.
    • For more information on how to solder and desolder connections, please visit this guide.
    FixBot'a Sor
    Yorum Ekle
  8. Solio Rocsta LED Replacement: adım 8, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Gently pry the LEDs using one of the Precision Tweezers.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
David Vazquez
577 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S13-G13, Cagle Fall 2017 USF Tampa, Team S13-G13, Cagle Fall 2017 üyesi
USFT-CAGLE-F17S13G13
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 38
Her zaman: 358
