Ana içeriğe geç
Sonos Roam Speaker Module Replacement
Neye ihtiyacın var
  1. Sonos Roam Speaker Module Replacement, End Caps: adım 1, 3 resimden 1. Sonos Roam Speaker Module Replacement, End Caps: adım 1, 3 resimden 2. Sonos Roam Speaker Module Replacement, End Caps: adım 1, 3 resimden 3.
    • Power off your Sonos Roam before beginning disassembly.
    • Use the metal spudger to pry the end cap with the buttons.
    • Pry from all sides to loosen the adhesive.
    • Use the iOpener, a blowdryer, or a similar heating device to loosen the adhesive if having difficulty.
    FixBot'a Sor
    Yorum Ekle
  2. Sonos Roam Speaker Module Replacement: adım 2, 2 resimden 1. Sonos Roam Speaker Module Replacement: adım 2, 2 resimden 2.
    • Flip the device to the other end cap.
    • Use the metal spudger to loosen the adhesive.
    FixBot'a Sor
    Yorum Ekle
  3. Sonos Roam Speaker Module Replacement, Speaker Grille: adım 3, 2 resimden 1. Sonos Roam Speaker Module Replacement, Speaker Grille: adım 3, 2 resimden 2.
    • Flip the device so that the Sonos logo is on the top.
    • Use the Torx T6 screwdriver to remove the two 6 mm screws.
    FixBot'a Sor
    Yorum Ekle
  4. Sonos Roam Speaker Module Replacement: adım 4, 2 resimden 1. Sonos Roam Speaker Module Replacement: adım 4, 2 resimden 2.
    • Flip the device.
    FixBot'a Sor
    Yorum Ekle
  5. Sonos Roam Speaker Module Replacement: adım 5, 3 resimden 1. Sonos Roam Speaker Module Replacement: adım 5, 3 resimden 2. Sonos Roam Speaker Module Replacement: adım 5, 3 resimden 3.
    • Flip the device so the Sonos logo is on the top.
    • Use the iFixit opening picks to wedge between the split of the grille and the back of the speaker to pry the grille apart.
    FixBot'a Sor
    Yorum Ekle
  6. Sonos Roam Speaker Module Replacement, Speaker Module: adım 6, 2 resimden 1. Sonos Roam Speaker Module Replacement, Speaker Module: adım 6, 2 resimden 2.
    • Use the TR10 Torx screwdriver to remove the six 7 mm screws.
    FixBot'a Sor
    Yorum Ekle
  7. Sonos Roam Speaker Module Replacement: adım 7, 3 resimden 1. Sonos Roam Speaker Module Replacement: adım 7, 3 resimden 2. Sonos Roam Speaker Module Replacement: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Begin to carefully separate the speaker module from the device.
    • Firmly squeeze the middle of the plug using the tweezers to pull it out of the socket.
    • Separate the speaker module from the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Lauren Young
884 İtibar
5 adet Kılavuz yazıldı
Ekip
Utah Tech University, Team 1-2, McMurrin Fall 2023 Utah Tech University, Team 1-2, McMurrin Fall 2023 üyesi
UTAHTECH-MCMURRIN-F23S1G2
3 Üyeler
13 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 52
Her zaman: 1,812
