Ana içeriğe geç
Sony α6000 Lens Assembly Replacement
Neye ihtiyacın var
  1. Sony α6000 Lens Assembly Replacement, Battery: adım 1, 2 resimden 1. Sony α6000 Lens Assembly Replacement, Battery: adım 1, 2 resimden 2.
    • Begin by placing the camera facing upside down.
  2. Sony α6000 Lens Assembly Replacement: adım 2, 2 resimden 1. Sony α6000 Lens Assembly Replacement: adım 2, 2 resimden 2.
    • Slide the notched locking bar on the battery compartment from LOCK to OPEN.
  3. Sony α6000 Lens Assembly Replacement: adım 3, 2 resimden 1. Sony α6000 Lens Assembly Replacement: adım 3, 2 resimden 2.
    • Push the small blue bar horizontally off of the battery.
  4. Sony α6000 Lens Assembly Replacement: adım 4, 2 resimden 1. Sony α6000 Lens Assembly Replacement: adım 4, 2 resimden 2.
    • Remove the battery.
  5. Sony α6000 Lens Assembly Replacement, Lens Assembly: adım 5, 1 resimden 1.
    • Place the camera with the lens facing upwards.
    • Remove the four 1.75 mm Phillips #00 screws from the front face of the camera.
  6. Sony α6000 Lens Assembly Replacement: adım 6, 1 resimden 1.
    • Carefully remove the outer most silver ring from the lens assembly.
  7. Sony α6000 Lens Assembly Replacement: adım 7, 1 resimden 1.
    • Carefully remove the black ring from the lens assembly.
  8. Sony α6000 Lens Assembly Replacement: adım 8, 1 resimden 1.
    • Carefully remove the thin silver ring from the lens assembly.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 627
