Ana içeriğe geç
Sony Action Cam HDR-AS15 O-Ring Replacement
Justin Calean
Justin Calean ve 4 diğer katkıda bulunanlar
En son May 2, 2021 tarihinde güncellendi
5 dakika
Kolay
Adım Kırpıcı
If you find your waterproof case not as watertight as you had hoped, you might want to replace the O-ring. You will need a tool to pry the O-ring from the case.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Sony Action Cam HDR-AS15 O-Ring Replacement, Open the Waterproof Case: adım 1, 1 resimden 1.
    • To open the case, push the yellow "Open" tab located at the bottom of the case.
    • Pull out on the yellow tabs as indicated by the circles in the photo to unlock the lid. This may be a little tricky!
    • Then, remove the lid.
  2. Sony Action Cam HDR-AS15 O-Ring Replacement, Pry the O-ring from the Groove: adım 2, 1 resimden 1.
    • Take the plastic opening tool and wedge it between the O-ring and the groove.
    • Then, pry the O-ring until it is out of the groove.
  3. Sony Action Cam HDR-AS15 O-Ring Replacement, Remove the O-ring: adım 3, 1 resimden 1.
    • Now that the O-ring is out of the groove, remove the O-ring from the lid.
Sonuç
Justin Calean
421 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-2, Sullivan Winter 2015 USF Tampa, Team 1-2, Sullivan Winter 2015 üyesi
USFT-SULLIVAN-W15S1G2
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 30
Her zaman: 939
