Ana içeriğe geç
Sony Alpha NEX-3N Lens Release Button Replacement
Terrance
Terrance ve başka bir katkıda bulunan
En son November 25, 2022 tarihinde güncellendi
3 saat
Çok zor
Gramer Polisi
Madde imleri!
Topluluk-Katkılı Kılavuz
  1. Sony Alpha NEX-3N Lens Release Button Replacement, Getting Started: adım 1, 2 resimden 1. Sony Alpha NEX-3N Lens Release Button Replacement, Getting Started: adım 1, 2 resimden 2.
    • Remove battery and card
  2. Sony Alpha NEX-3N Lens Release Button Replacement, Back Case 1: adım 2, 3 resimden 1. Sony Alpha NEX-3N Lens Release Button Replacement, Back Case 1: adım 2, 3 resimden 2. Sony Alpha NEX-3N Lens Release Button Replacement, Back Case 1: adım 2, 3 resimden 3.
    • Right side, remove 1 M1.4x3.7 screw
    • Left side, remove 3 M1.4x3.7 screws
    • Bottom side, remove 5 M1.4x3.7 screws, including 2 in battery bay. 2 of them out of this photo, you can find them.
    • Do NOT touch screws on the bottom of LCD assembly.
  3. Sony Alpha NEX-3N Lens Release Button Replacement, Back Case 2: adım 3, 1 resimden 1.
    • Pop the flash.
    • In flash room, remove 1 (one) M1.4x3.8 black screw.
  4. Sony Alpha NEX-3N Lens Release Button Replacement, Back Case 3: adım 4, 3 resimden 1. Sony Alpha NEX-3N Lens Release Button Replacement, Back Case 3: adım 4, 3 resimden 2. Sony Alpha NEX-3N Lens Release Button Replacement, Back Case 3: adım 4, 3 resimden 3.
    • Remove LCD hinge cover, by sliding to the left.
    • Remove back cover, actually just a plastic frame.
  5. Sony Alpha NEX-3N Lens Release Button Replacement, LCD assembly: adım 5, 2 resimden 1. Sony Alpha NEX-3N Lens Release Button Replacement, LCD assembly: adım 5, 2 resimden 2.
    • Remove 1 M1.4x2 screw
    • Remove another M1.4x2 screw, sorry for the angle.
  6. Sony Alpha NEX-3N Lens Release Button Replacement, LCD Assembly: adım 6, 3 resimden 1. Sony Alpha NEX-3N Lens Release Button Replacement, LCD Assembly: adım 6, 3 resimden 2. Sony Alpha NEX-3N Lens Release Button Replacement, LCD Assembly: adım 6, 3 resimden 3.
    • CAUTION. Sony makes world's MOST BRITTLE FPC!
    • Loosen LCD assemble with caution!
    • Release FPC cable, the connector is flip type.
  7. Sony Alpha NEX-3N Lens Release Button Replacement, The LCD assembly: adım 7, 1 resimden 1.
    • The LCD assembly
  8. Sony Alpha NEX-3N Lens Release Button Replacement, Dismantle the LCD Part: adım 8, 3 resimden 1. Sony Alpha NEX-3N Lens Release Button Replacement, Dismantle the LCD Part: adım 8, 3 resimden 2. Sony Alpha NEX-3N Lens Release Button Replacement, Dismantle the LCD Part: adım 8, 3 resimden 3.
    • After unscrew 4pcs screw you will remove the steel black plate, then slowly pull the black frame there to see the ribbon stripe.
    • Slowly pull the very fragile ribbon lock which i marking with the blue boxes. around just 1mm to unlock the ribbon.. unlucky i broke mine..
  9. Sony Alpha NEX-3N Lens Release Button Replacement, Dismantle the LCD Part: adım 9, 3 resimden 1. Sony Alpha NEX-3N Lens Release Button Replacement, Dismantle the LCD Part: adım 9, 3 resimden 2. Sony Alpha NEX-3N Lens Release Button Replacement, Dismantle the LCD Part: adım 9, 3 resimden 3.
    • you can see the ribbon already pull out but be carefull with the others 2 ribbon when your try to pull out this ribbon.
    • the the circle marker that show others ribbon you need to be carefull. goodluck!
  10. Sony Alpha NEX-3N Lens Release Button Replacement, Keypad: adım 10, 3 resimden 1. Sony Alpha NEX-3N Lens Release Button Replacement, Keypad: adım 10, 3 resimden 2. Sony Alpha NEX-3N Lens Release Button Replacement, Keypad: adım 10, 3 resimden 3.
    • Lift the keypad.
    • Detach FPC
  11. Sony Alpha NEX-3N Lens Release Button Replacement, Screws: adım 11, 1 resimden 1.
    • Remove 3 M1.4x3.6 black screws, 2 of them out of focus
  12. Sony Alpha NEX-3N Lens Release Button Replacement: adım 12, 2 resimden 1. Sony Alpha NEX-3N Lens Release Button Replacement: adım 12, 2 resimden 2.
    • Slide the flash assembly backwards with caution.
    • Detach flash FPC by pulling it out of the socket.
    • High Voltage! Do NOT touch metal on FPC.
    • Then remove the flash assembly.
  13. Sony Alpha NEX-3N Lens Release Button Replacement: adım 13, 1 resimden 1.
    • Remove that part whatever called, by sliding it backwards.
  14. Sony Alpha NEX-3N Lens Release Button Replacement, Screws: adım 14, 3 resimden 1. Sony Alpha NEX-3N Lens Release Button Replacement, Screws: adım 14, 3 resimden 2. Sony Alpha NEX-3N Lens Release Button Replacement, Screws: adım 14, 3 resimden 3.
    • 1 ST1.7x5
    • 2 ST1.7x5
    • 1 M1.4x3.6 black
  15. Sony Alpha NEX-3N Lens Release Button Replacement, The Grip: adım 15, 2 resimden 1. Sony Alpha NEX-3N Lens Release Button Replacement, The Grip: adım 15, 2 resimden 2.
    • Remove 2 ST1.7x5 screws from inside the battery bay. (one of them not shown, deeper inside) insert screw driver through a hole in the shielding cover.
    • Pop the grip off. From back, push to the right, then it flies forward.
  16. Sony Alpha NEX-3N Lens Release Button Replacement, More Screws: adım 16, 1 resimden 1.
    • Remove 2 M1.4x2 black screws
  17. Sony Alpha NEX-3N Lens Release Button Replacement, Pop the Shielding Cover: adım 17, 2 resimden 1. Sony Alpha NEX-3N Lens Release Button Replacement, Pop the Shielding Cover: adım 17, 2 resimden 2.
    • with caution and patient.
  18. Sony Alpha NEX-3N Lens Release Button Replacement, One More Shield: adım 18, 3 resimden 1. Sony Alpha NEX-3N Lens Release Button Replacement, One More Shield: adım 18, 3 resimden 2. Sony Alpha NEX-3N Lens Release Button Replacement, One More Shield: adım 18, 3 resimden 3.
    • 1 M1.4x3.6
  19. Sony Alpha NEX-3N Lens Release Button Replacement, Detach 7000 FPCs: adım 19, 1 resimden 1.
    • Sensor power, flip
    • Sensor signal, flip
    • Shutter, pull
    • Lens contacts, pull. Did I mention that Sony makes world's most brittle FPC?
    • Whatever, pull
    • Whatever, pull
    • Shutter charger motor FPC, (backside, pull out)
  20. Sony Alpha NEX-3N Lens Release Button Replacement: adım 20, 1 resimden 1.
    • Flip the Mainboard up
    • Pull out one more FPC
    • Discharge then desolder 4 wires.
    • CAUTION! Possible high DC voltage >300V
  21. Sony Alpha NEX-3N Lens Release Button Replacement: adım 21, 1 resimden 1.
    • Lift main board and plastic frame with flash capacitor.
  22. Sony Alpha NEX-3N Lens Release Button Replacement, FPC cables: adım 22, 1 resimden 1.
    • Detach sensor Power (L)and Signal(R) FPC
  23. Sony Alpha NEX-3N Lens Release Button Replacement, Screws: adım 23, 1 resimden 1.
    • Remove 3-4 ST1.7x5 screws
    • Remove 1 M1.4x5 screw
  24. Sony Alpha NEX-3N Lens Release Button Replacement: adım 24, 2 resimden 1. Sony Alpha NEX-3N Lens Release Button Replacement: adım 24, 2 resimden 2.
    • Remove 4 ST1.7x5 screws for the E-Mount
    • Remove mount metal ring
  25. Sony Alpha NEX-3N Lens Release Button Replacement, E-Mount: adım 25, 3 resimden 1. Sony Alpha NEX-3N Lens Release Button Replacement, E-Mount: adım 25, 3 resimden 2. Sony Alpha NEX-3N Lens Release Button Replacement, E-Mount: adım 25, 3 resimden 3.
    • Remove mount plastic ring
    • remove mount spring ring
  26. Sony Alpha NEX-3N Lens Release Button Replacement, Sensor + Shutter: adım 26, 1 resimden 1.
    • Sensor + Shutter assembly comes off
  27. Sony Alpha NEX-3N Lens Release Button Replacement, Sensor Frame: adım 27, 1 resimden 1.
    • Separate sensor + shutter from another frame
  28. Sony Alpha NEX-3N Lens Release Button Replacement, The Sensor: adım 28, 3 resimden 1. Sony Alpha NEX-3N Lens Release Button Replacement, The Sensor: adım 28, 3 resimden 2. Sony Alpha NEX-3N Lens Release Button Replacement, The Sensor: adım 28, 3 resimden 3.
    • Remove 3 ST1.7x5 screws
    • Remove sensor shield / heat sink. Sensor PCBA might sticks to the shield, just separate them.
  29. Sony Alpha NEX-3N Lens Release Button Replacement, Shutter: adım 29, 2 resimden 1. Sony Alpha NEX-3N Lens Release Button Replacement, Shutter: adım 29, 2 resimden 2.
    • Remove sensor. the shutter assembly comes off.
    • Careful with 3 tiny spacers. Do NOT lose them.
  30. Sony Alpha NEX-3N Lens Release Button Replacement: adım 30, 1 resimden 1.
    • Separate Shutter assembly form the mount body.
  31. Sony Alpha NEX-3N Lens Release Button Replacement: adım 31, 3 resimden 1. Sony Alpha NEX-3N Lens Release Button Replacement: adım 31, 3 resimden 2. Sony Alpha NEX-3N Lens Release Button Replacement: adım 31, 3 resimden 3.
    • Remove 1 screw (from the "Front" side)
    • Separate shutter curtain (Photo 3) from charging motor (not shown).
  32. Sony Alpha NEX-3N Lens Release Button Replacement, Lens Release Button: adım 32, 1 resimden 1.
    • Yes, replacing this little innocent part needs 3+ hours!
  33. Sony Alpha NEX-3N Lens Release Button Replacement: adım 33, 1 resimden 1.
    • After removing the mount+shutter+sensor, it appears.
Sonuç
Terrance
6.455 İtibar
17 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 106
