Ana içeriğe geç
Sony Alpha a7S II Viewfinder Plate Replacement
Neye ihtiyacın var
  1. Sony Alpha a7S II Viewfinder Plate Replacement, Diopter: adım 1, 1 resimden 1.
    • Orient your camera so that you are looking at the posterior portion.
  2. Sony Alpha a7S II Viewfinder Plate Replacement: adım 2, 1 resimden 1.
    • Place each of your thumbs on the interior portions of the eyepiece cup, pressing down and pushing up.
  3. Sony Alpha a7S II Viewfinder Plate Replacement: adım 3, 1 resimden 1.
    • Slide the eyepiece off by carefully pulling it upward.
    • Be careful not to come into contact with the viewfinder lens as the lens can be easily scratched.
  4. Sony Alpha a7S II Viewfinder Plate Replacement: adım 4, 1 resimden 1.
    • Remove the screw from the middle of the diopter with the JIS #00 screwdriver.
  5. Sony Alpha a7S II Viewfinder Plate Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove the diopter with your hands. If the diopter is at all stuck you can use the pointed tweezers to help aid in the removal process.
    • Be careful not to let fingers or tweezers come into contact with the viewfinder lens as the lens can be easily scratched.
  6. Sony Alpha a7S II Viewfinder Plate Replacement, Viewfinder Plate: adım 6, 1 resimden 1.
    • Remove the 4 screws on the viewfinder plate with a JIS #00 screwdriver.
  7. Sony Alpha a7S II Viewfinder Plate Replacement: adım 7, 2 resimden 1. Sony Alpha a7S II Viewfinder Plate Replacement: adım 7, 2 resimden 2.
    • Carefully remove the plastic viewfinder plate from the camera.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 24
Son 30 gün: 50
Her zaman: 4,957
