Ana içeriğe geç
Sony BDP-S3500 Disk Drive Replacement
Neye ihtiyacın var
  1. Sony BDP-S3500 Disk Drive Replacement, Front Panel: adım 1, 2 resimden 1. Sony BDP-S3500 Disk Drive Replacement, Front Panel: adım 1, 2 resimden 2.
    • Use the Phillips #2 screwdriver to remove the two 9mm screws located on the back of the device.
    FixBot'a Sor
    Yorum Ekle
  2. Sony BDP-S3500 Disk Drive Replacement: adım 2, 1 resimden 1.
    • Slide the top panel off towards the back of the device.
    • Remove the top panel.
    FixBot'a Sor
    Yorum Ekle
  3. Sony BDP-S3500 Disk Drive Replacement: adım 3, 2 resimden 1. Sony BDP-S3500 Disk Drive Replacement: adım 3, 2 resimden 2.
    • Unclip the plastic tags from the bottom of the device.
    • Unclip the plastic tags from the sides of the device.
    • Slide the front panel off.
    FixBot'a Sor
    Yorum Ekle
  4. Sony BDP-S3500 Disk Drive Replacement, Disk Drive: adım 4, 2 resimden 1. Sony BDP-S3500 Disk Drive Replacement, Disk Drive: adım 4, 2 resimden 2.
    • Remove the three ribbon cables by gently pulling the cables out of each connector.
    • Be sure to only handle the circuit board from the edges so that the PCB is not damaged.
    FixBot'a Sor
    Yorum Ekle
  5. Sony BDP-S3500 Disk Drive Replacement: adım 5, 2 resimden 1. Sony BDP-S3500 Disk Drive Replacement: adım 5, 2 resimden 2.
    • Use a Phillips #2 screwdriver to remove the two 9mm screws that are holding the disk drive in place.
    FixBot'a Sor
    Yorum Ekle
  6. Sony BDP-S3500 Disk Drive Replacement: adım 6, 2 resimden 1. Sony BDP-S3500 Disk Drive Replacement: adım 6, 2 resimden 2.
    • Carefully lift and slide the disk drive out of the casing.
    FixBot'a Sor
    Yorum Ekle
Sonuç
V W
197 İtibar
1 Kılavuz yazıldı
Ekip
1Rehber Yorum
Hello, great guide thank you. How do you go about finding the correct replacement drive?
Andy Day - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 33
Her zaman: 827
