Ana içeriğe geç
Sony BDP-S3500 Motherboard Replacement
Neye ihtiyacın var
  1. Sony BDP-S3500 Motherboard Replacement, Front Panel: adım 1, 2 resimden 1. Sony BDP-S3500 Motherboard Replacement, Front Panel: adım 1, 2 resimden 2.
    • Use the Phillips #2 screwdriver to remove the two 9mm screws located on the back of the device.
  2. Sony BDP-S3500 Motherboard Replacement: adım 2, 1 resimden 1.
    • Slide the top panel off towards the back of the device.
    • Remove the top panel.
  3. Sony BDP-S3500 Motherboard Replacement: adım 3, 2 resimden 1. Sony BDP-S3500 Motherboard Replacement: adım 3, 2 resimden 2.
    • Unclip the plastic tags from the bottom of the device.
    • Unclip the plastic tags from the sides of the device.
    • Slide the front panel off.
  4. Sony BDP-S3500 Motherboard Replacement, Disk Drive: adım 4, 2 resimden 1. Sony BDP-S3500 Motherboard Replacement, Disk Drive: adım 4, 2 resimden 2.
    • Remove the three ribbon cables by gently pulling the cables out of each connector.
    • Be sure to only handle the circuit board from the edges so that the PCB is not damaged.
  5. Sony BDP-S3500 Motherboard Replacement: adım 5, 2 resimden 1. Sony BDP-S3500 Motherboard Replacement: adım 5, 2 resimden 2.
    • Use a Phillips #2 screwdriver to remove the two 9mm screws that are holding the disk drive in place.
  6. Sony BDP-S3500 Motherboard Replacement: adım 6, 2 resimden 1. Sony BDP-S3500 Motherboard Replacement: adım 6, 2 resimden 2.
    • Carefully lift and slide the disk drive out of the casing.
  7. Sony BDP-S3500 Motherboard Replacement, Motherboard: adım 7, 2 resimden 1. Sony BDP-S3500 Motherboard Replacement, Motherboard: adım 7, 2 resimden 2.
    • Remove the ribbon cables by holding onto the cable and gently pulling straight up.
  8. Sony BDP-S3500 Motherboard Replacement: adım 8, 3 resimden 1. Sony BDP-S3500 Motherboard Replacement: adım 8, 3 resimden 2. Sony BDP-S3500 Motherboard Replacement: adım 8, 3 resimden 3.
    • Use the Phillips #2 screwdriver to remove three 9mm screws securing the motherboard to the case.
    • Remove one 5.5mm Phillips #2 from the back of the case near the ports.
  9. Sony BDP-S3500 Motherboard Replacement: adım 9, 1 resimden 1.
    • Slide the motherboard away from the back of the case and then lift up to remove.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Michael Meissner
220 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 473
