Ana içeriğe geç
Sony BDP-S3500 Port Board Replacement
Neye ihtiyacın var
  1. Sony BDP-S3500 Port Board Replacement, Front Panel: adım 1, 2 resimden 1. Sony BDP-S3500 Port Board Replacement, Front Panel: adım 1, 2 resimden 2.
    • Use the Phillips #2 screwdriver to remove the two 9mm screws located on the back of the device.
  2. Sony BDP-S3500 Port Board Replacement: adım 2, 1 resimden 1.
    • Slide the top panel off towards the back of the device.
    • Remove the top panel.
  3. Sony BDP-S3500 Port Board Replacement: adım 3, 2 resimden 1. Sony BDP-S3500 Port Board Replacement: adım 3, 2 resimden 2.
    • Unclip the plastic tags from the bottom of the device.
    • Unclip the plastic tags from the sides of the device.
    • Slide the front panel off.
  4. Sony BDP-S3500 Port Board Replacement, Port Board: adım 4, 2 resimden 1. Sony BDP-S3500 Port Board Replacement, Port Board: adım 4, 2 resimden 2.
    • Keep the back side up and facing towards you.
    • Carefully disconnect the blue ribbon connecting the port board and motherboard.
    • Be delicate while removing the ribbon.
  5. Sony BDP-S3500 Port Board Replacement: adım 5, 1 resimden 1.
    • Use a Phillips #2 screwdriver to remove the 9mm screw from the port board.
  6. Sony BDP-S3500 Port Board Replacement: adım 6, 1 resimden 1.
    • Remove the port board from the device.
Sonuç
Megh Ladumor
100 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 268
