Ana içeriğe geç
Sony BDP-S3500 Wi-Fi Module Replacement
Neye ihtiyacın var
  1. Sony BDP-S3500 Wi-Fi Module Replacement, Front Panel: adım 1, 2 resimden 1. Sony BDP-S3500 Wi-Fi Module Replacement, Front Panel: adım 1, 2 resimden 2.
    • Use the Phillips #2 screwdriver to remove the two 9mm screws located on the back of the device.
    FixBot'a Sor
    Yorum Ekle
  2. Sony BDP-S3500 Wi-Fi Module Replacement: adım 2, 1 resimden 1.
    • Slide the top panel off towards the back of the device.
    • Remove the top panel.
    FixBot'a Sor
    Yorum Ekle
  3. Sony BDP-S3500 Wi-Fi Module Replacement: adım 3, 2 resimden 1. Sony BDP-S3500 Wi-Fi Module Replacement: adım 3, 2 resimden 2.
    • Unclip the plastic tags from the bottom of the device.
    • Unclip the plastic tags from the sides of the device.
    • Slide the front panel off.
    FixBot'a Sor
    Yorum Ekle
  4. Sony BDP-S3500 Wi-Fi Module Replacement, Port Board: adım 4, 2 resimden 1. Sony BDP-S3500 Wi-Fi Module Replacement, Port Board: adım 4, 2 resimden 2.
    • Keep the back side up and facing towards you.
    • Carefully disconnect the blue ribbon connecting the port board and motherboard.
    • Be delicate while removing the ribbon.
    FixBot'a Sor
    Yorum Ekle
  5. Sony BDP-S3500 Wi-Fi Module Replacement: adım 5, 1 resimden 1.
    • Use a Phillips #2 screwdriver to remove the 9mm screw from the port board.
    FixBot'a Sor
    Yorum Ekle
  6. Sony BDP-S3500 Wi-Fi Module Replacement: adım 6, 1 resimden 1.
    • Remove the port board from the device.
    FixBot'a Sor
    Yorum Ekle
  7. Sony BDP-S3500 Wi-Fi Module Replacement, Wi-Fi Module: adım 7, 1 resimden 1.
    • Remove the white ribbon cable connecting the Wi-Fi module to the motherboard by gently pulling it out.
    FixBot'a Sor
    Yorum Ekle
  8. Sony BDP-S3500 Wi-Fi Module Replacement: adım 8, 1 resimden 1.
    • Use a Phillips #2 screwdriver to remove the 7mm screw from the Wi-Fi module.
    FixBot'a Sor
    Yorum Ekle
  9. Sony BDP-S3500 Wi-Fi Module Replacement: adım 9, 1 resimden 1.
    • The Wi-Fi module can now be safely removed.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bushra Banuso
97 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 22
Her zaman: 741
