Ana içeriğe geç
Sony BDP-s7200 Motherboard Replacement
Neye ihtiyacın var
  1. Sony BDP-s7200  Motherboard Replacement, Back Cover: adım 1, 1 resimden 1.
    • Remove the disk tray cover from the device.
  2. Sony BDP-s7200  Motherboard Replacement: adım 2, 2 resimden 1. Sony BDP-s7200  Motherboard Replacement: adım 2, 2 resimden 2.
    • Using the Phillips #2 Screwdriver, remove the five 9mm from the bottom of the device.
    • Remove the metal cover.
  3. Sony BDP-s7200  Motherboard Replacement: adım 3, 2 resimden 1. Sony BDP-s7200  Motherboard Replacement: adım 3, 2 resimden 2.
    • Using the Phillips #2 Screwdriver, remove the six 9mm screws from the back of the device.
  4. Sony BDP-s7200  Motherboard Replacement: adım 4, 1 resimden 1.
    • Pull off the back panel and remove it from the device.
  5. Sony BDP-s7200  Motherboard Replacement, Front Panel Cover: adım 5, 3 resimden 1. Sony BDP-s7200  Motherboard Replacement, Front Panel Cover: adım 5, 3 resimden 2. Sony BDP-s7200  Motherboard Replacement, Front Panel Cover: adım 5, 3 resimden 3.
    • Using the plastic opening tool, open one of the tabs on the bottom of the device.
    • While keeping the tab open, insert a opening pick in between the opening tool and tab.
    • Repeat this for the 3 other tabs.
  6. Sony BDP-s7200  Motherboard Replacement: adım 6, 2 resimden 1. Sony BDP-s7200  Motherboard Replacement: adım 6, 2 resimden 2.
    • Place your hands on the two black circles on the bottom of the device.
    • Pull on the black circles to remove the device from its front panel cover.
  7. Sony BDP-s7200  Motherboard Replacement: adım 7, 3 resimden 1. Sony BDP-s7200  Motherboard Replacement: adım 7, 3 resimden 2. Sony BDP-s7200  Motherboard Replacement: adım 7, 3 resimden 3.
    • Using the Phillips #2 Screwdriver, remove the seven 9mm screws from the top of the device.
    • Using the same screwdriver, remove the three 9mm screws from the back of the device.
    • Using the same screwdriver, remove the one 9mm screw still connecting the small metal clip to the front of the device.
  8. Sony BDP-s7200  Motherboard Replacement: adım 8, 2 resimden 1. Sony BDP-s7200  Motherboard Replacement: adım 8, 2 resimden 2.
    • Remove the small metal clip on the front of the device.
    • Remove the metal cover on the top of the device.
  9. Sony BDP-s7200  Motherboard Replacement, Motherboard: adım 9, 2 resimden 1. Sony BDP-s7200  Motherboard Replacement, Motherboard: adım 9, 2 resimden 2.
    • Remove the ribbon cables connected to the front panel board.
    • Pull firmly, but not too hard as to not damage the ribbon cable.
  10. Sony BDP-s7200  Motherboard Replacement: adım 10, 1 resimden 1.
    • Remove the cable connected to the power supply.
  11. Sony BDP-s7200  Motherboard Replacement: adım 11, 1 resimden 1.
    • Remove the ribbon cables that connect the motherboard to the disk drive.
    • Pull firmly, but not too hard as to not damage the ribbon cables.
  12. Sony BDP-s7200  Motherboard Replacement: adım 12, 3 resimden 1. Sony BDP-s7200  Motherboard Replacement: adım 12, 3 resimden 2. Sony BDP-s7200  Motherboard Replacement: adım 12, 3 resimden 3.
    • Remove the three screws using the Phillips #2 Screwdriver.
    • Do not attempt to remove. There is one additional screw on the back of the device.
    • Remove the screw on the back of the device with the same screwdriver.
  13. Sony BDP-s7200  Motherboard Replacement: adım 13, 2 resimden 1. Sony BDP-s7200  Motherboard Replacement: adım 13, 2 resimden 2.
    • Lift the motherboard from the front and carefully pull it out.
    • There is a small square adhesive on the bottom. Leave it there for reassembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 392
