Ana içeriğe geç
Sony Cyber-Shot DSC-S90 Back Case Replacement
Alecsander da Silva
Alecsander da Silva ve 3 diğer katkıda bulunanlar
En son January 23, 2021 tarihinde güncellendi
5 dakika
Kolay
This guide will primarily focus on the replacement and disassembly of the back casing of the Sony Cyber-Shot DSC-S90 camera. This is an easy step by step process that should give you little to no difficulty.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Sony Cyber-Shot DSC-S90 Back Case Replacement, Batteries: adım 1, 2 resimden 1. Sony Cyber-Shot DSC-S90 Back Case Replacement, Batteries: adım 1, 2 resimden 2.
    • Hold down the "open"button (gray oval with arrow pointing upwards) on the battery port door.
    • While holding the button downwards, slide the door upwards to unlock and open the door.
  2. Sony Cyber-Shot DSC-S90 Back Case Replacement: adım 2, 1 resimden 1.
    • Pull open the door and allow the batteries to fall out.
  3. Sony Cyber-Shot DSC-S90 Back Case Replacement, Back Case: adım 3, 2 resimden 1. Sony Cyber-Shot DSC-S90 Back Case Replacement, Back Case: adım 3, 2 resimden 2.
    • Remove the 2mm Phillips #00 screw under the battery port door.
    • Remove the 2mm Phillips #00 screw towards the right of the bottom-side of the camera.
  4. Sony Cyber-Shot DSC-S90 Back Case Replacement: adım 4, 2 resimden 1. Sony Cyber-Shot DSC-S90 Back Case Replacement: adım 4, 2 resimden 2.
    • Remove the two 2mm Phillips #00 screws (one on each side of the camera).
  5. Sony Cyber-Shot DSC-S90 Back Case Replacement: adım 5, 2 resimden 1. Sony Cyber-Shot DSC-S90 Back Case Replacement: adım 5, 2 resimden 2.
    • Use an opening tool to unlock the front case from the main body of the camera. Use the tool on the right side and bottom of the camera with the LCD screen facing you.
  6. Sony Cyber-Shot DSC-S90 Back Case Replacement: adım 6, 1 resimden 1.
    • Pull apart the back case from the main body of the camera.
Sonuç
Alecsander da Silva
314 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G5, Saloman Fall 2019 UMass Dartmouth, Team S4-G5, Saloman Fall 2019 üyesi
UMASSD-SALOMAN-F19S4G5
3 Üyeler
20 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 26
Her zaman: 269
