Ana içeriğe geç
Sony Cyber-Shot DSC-TX9 Card Reader Replacement
Yegor Shea
Yegor Shea ve 2 diğer katkıda bulunanlar
En son February 1, 2021 tarihinde güncellendi
10 - 25 dakika
Orta
İşlem Görüntüleri
This guide will demonstrate how to replace the Memory Card Reader. This will fix the "Unable to read memory card" Error.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Sony Cyber-Shot DSC-TX9 Card Reader Replacement, Prerequisites Only: adım 1, 3 resimden 1. Sony Cyber-Shot DSC-TX9 Card Reader Replacement, Prerequisites Only: adım 1, 3 resimden 2. Sony Cyber-Shot DSC-TX9 Card Reader Replacement, Prerequisites Only: adım 1, 3 resimden 3.
    • Use a Phillips #0 screwdriver to unscrew the six 2mm screws on the outer case of the camera.
    • If there is a battery or SD card inside remove before beginning the process.
  2. Sony Cyber-Shot DSC-TX9 Card Reader Replacement: adım 2, 2 resimden 1. Sony Cyber-Shot DSC-TX9 Card Reader Replacement: adım 2, 2 resimden 2.
    • Use your hands or a Spudger to Pull off the front cover of the camera.
    • If the casing is not coming apart easily, do not force it.
  3. Sony Cyber-Shot DSC-TX9 Card Reader Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove the protective black cover layer with your hands and set it aside.
    • The use of tweezers may be necessary if the cover is difficult to remove.
  4. Sony Cyber-Shot DSC-TX9 Card Reader Replacement: adım 4, 2 resimden 1. Sony Cyber-Shot DSC-TX9 Card Reader Replacement: adım 4, 2 resimden 2.
    • The ZIF connector can be removed by flipping the small black holder into the upright position and then sliding the ribbon cable out carefully.
    • Once this has been done, use tweezers to unplug the flat topped connector for the lens’ circuit board from the motherboard.
    • DO NOT force the ribbon cables or they will rip.
    • Refer to the (Recognizing & Disconnecting Cable Connectors) page for assistance.
  5. Sony Cyber-Shot DSC-TX9 Card Reader Replacement, Card Reader: adım 5, 3 resimden 1. Sony Cyber-Shot DSC-TX9 Card Reader Replacement, Card Reader: adım 5, 3 resimden 2. Sony Cyber-Shot DSC-TX9 Card Reader Replacement, Card Reader: adım 5, 3 resimden 3.
    • Using a Phillips head screw driver, remove the two screws for the metal plate on the bottom.
    • Detach the smaller ribbon cables by sliding them out.
    • Detach the large ribbon cable by flipping the small black holder in an upright position and then sliding the cable out carefully.
    • Detach the ribbon cables slowly and carefully or they will rip.
  6. Sony Cyber-Shot DSC-TX9 Card Reader Replacement: adım 6, 2 resimden 1. Sony Cyber-Shot DSC-TX9 Card Reader Replacement: adım 6, 2 resimden 2.
    • Carefully remove the Memory card circuit board.
    • The circuit board should come out with little force. If it does not, make sure all connections are disconnected.
Sonuç
Yegor Shea
301 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G3, Julie Spring 2017 UMass Dartmouth, Team S4-G3, Julie Spring 2017 üyesi
UMASSD-JULIE-S17S4G3
5 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 431
