Ana içeriğe geç
Sony Cyber-Shot DSC-W830 LCD Replacement
Neye ihtiyacın var
  1. Sony Cyber-Shot DSC-W830 LCD Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the lock at the bottom of the camera to "Open".
    • The door to the battery pack is spring loaded.
  2. Sony Cyber-Shot DSC-W830 LCD Replacement: adım 2, 1 resimden 1.
    • Slide the blue clip up and away from the battery.
  3. Sony Cyber-Shot DSC-W830 LCD Replacement: adım 3, 1 resimden 1.
    • Remove the battery.
  4. Sony Cyber-Shot DSC-W830 LCD Replacement, Front and Back Panel: adım 4, 3 resimden 1. Sony Cyber-Shot DSC-W830 LCD Replacement, Front and Back Panel: adım 4, 3 resimden 2. Sony Cyber-Shot DSC-W830 LCD Replacement, Front and Back Panel: adım 4, 3 resimden 3.
    • Remove the six 3.5mm Phillips #000 screws.
    • Rotate the lock away from the camera.
  5. Sony Cyber-Shot DSC-W830 LCD Replacement: adım 5, 3 resimden 1. Sony Cyber-Shot DSC-W830 LCD Replacement: adım 5, 3 resimden 2. Sony Cyber-Shot DSC-W830 LCD Replacement: adım 5, 3 resimden 3.
    • Pry the device open with the plastic opening tool.
    • There are two clips that help prevent the front panel from separating.
  6. Sony Cyber-Shot DSC-W830 LCD Replacement: adım 6, 3 resimden 1. Sony Cyber-Shot DSC-W830 LCD Replacement: adım 6, 3 resimden 2. Sony Cyber-Shot DSC-W830 LCD Replacement: adım 6, 3 resimden 3.
    • Remove the two plastic spacers between the front and the back panels.
    • The spacers may fall out when removing the panels.
    • Carefully remove the back panel.
  7. Sony Cyber-Shot DSC-W830 LCD Replacement, Button Board: adım 7, 2 resimden 1. Sony Cyber-Shot DSC-W830 LCD Replacement, Button Board: adım 7, 2 resimden 2.
    • Gently release the button board from the clips.
    • Be careful when lifting the button board; the ribbon cable will still be attached.
  8. Sony Cyber-Shot DSC-W830 LCD Replacement: adım 8, 2 resimden 1. Sony Cyber-Shot DSC-W830 LCD Replacement: adım 8, 2 resimden 2.
    • Disconnect the no-fuss ribbon cable by gently pulling it out of the button board.
  9. Sony Cyber-Shot DSC-W830 LCD Replacement, LCD: adım 9, 2 resimden 1. Sony Cyber-Shot DSC-W830 LCD Replacement, LCD: adım 9, 2 resimden 2.
    • Push the bottom right corner of the LCD screen out and slide it to the right to release it from the clips.
    • Be careful when lifting the LCD screen; the ribbon cable will still be attached.
  10. Sony Cyber-Shot DSC-W830 LCD Replacement: adım 10, 2 resimden 1. Sony Cyber-Shot DSC-W830 LCD Replacement: adım 10, 2 resimden 2.
    • Grasp the no-fuss ribbon cable and gently pull it out from the motherboard.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Addyson Salalila
316 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-1, Blackwell Fall 2016 USF Tampa, Team 17-1, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S17G1
4 Üyeler
6 adet Kılavuz yazıldı
5Kılavuz Yorumları
hii
plaz help me
tajbhatnagar - Yanıt
Sony Cyber-Shot DSC-W830 LCD ……WowObjects LCD Display Screen For SONY DSC-W150 same hai ya different hai
Hi I need a one DSC w810 display how much. ?
How can contact you ?
Tamil Varshitha - Yanıt
Sony dsc s2000 model camera need
Display & lens unit
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 58
Her zaman: 5,349
