Ana içeriğe geç
Sony Cyber-shot DSC-H20 Flash Assembly Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-H20 Flash Assembly Replacement, Flash Assembly: adım 1, 2 resimden 1. Sony Cyber-shot DSC-H20 Flash Assembly Replacement, Flash Assembly: adım 1, 2 resimden 2.
    • Slide open the battery cover and remove the battery and the Memory Stick Duo.
    • Return the battery cover to its closed position.
  2. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: adım 2, 1 resimden 1.
    • Remove all three screws from the bottom of the camera.
  3. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: adım 3, 2 resimden 1. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: adım 3, 2 resimden 2.
    • Remove the screws on the left and right sides of the camera.
  4. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: adım 4, 3 resimden 1. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: adım 4, 3 resimden 2. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: adım 4, 3 resimden 3.
    • Press down on the flash cover to raise the flash.
    • Remove both screws that hold the flash cover to the body of the camera.
  5. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: adım 5, 2 resimden 1. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: adım 5, 2 resimden 2.
    • Place the camera upside down with the battery port positioned upward.
    • Slide open the battery port.
  6. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: adım 6, 3 resimden 1. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: adım 6, 3 resimden 2. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: adım 6, 3 resimden 3.
    • Pry the front cover of the camera off with the plastic opening tool.
  7. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: adım 7, 1 resimden 1.
    • Remove the power shutter unit
  8. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: adım 8, 2 resimden 1. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: adım 8, 2 resimden 2.
    • Unscrew the screw located at the back left corner of the flash component.
    • Set the flash component aside.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Reuben Martinez
333 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Leahy Winter 2015 USF Tampa, Team 1-1, Leahy Winter 2015 üyesi
USFT-LEAHY-W15S1G1
3 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
how to bye power sutter unit
aloke mondal - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 27
Her zaman: 1,510
