Ana içeriğe geç
Sony Cyber-shot DSC-HX1 Battery Replacement
Brianna Greenlaw
Brianna Greenlaw ve 3 diğer katkıda bulunanlar
En son January 13, 2021 tarihinde güncellendi
3 - 5 dakika
Çok kolay
This guide gives a simple step-by-step process for removing and/or replacing the battery. Battery removal is required for most other repairs of this device.
  1. Sony Cyber-shot DSC-HX1 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the surface you place the screen on is clean of debris and dust. Otherwise you risk scratching your screen.
    • Place the camera with the bottom facing you and the lens facing up.
  2. Sony Cyber-shot DSC-HX1 Battery Replacement: adım 2, 1 resimden 1.
    • Push down and away from the camera to the left on the indicated indentation in the battery cover. The compartment should slide open as shown.
  3. Sony Cyber-shot DSC-HX1 Battery Replacement: adım 3, 2 resimden 1. Sony Cyber-shot DSC-HX1 Battery Replacement: adım 3, 2 resimden 2.
    • Push the blue tab towards the camera body to the right, while simultaneously pulling out the battery.
    • The battery is not shown here. However, normally the battery would be in the displayed compartment.
Sonuç
To reassemble your device, insert the new battery in the compartment, making sure that your battery has the correct orientation, then follow these instructions in reverse order.
Brianna Greenlaw
1.217 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-3, Forte Spring 2015 Cal Poly, Team 17-3, Forte Spring 2015 üyesi
CPSU-FORTE-S15S17G3
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 17
Son 30 gün: 34
Her zaman: 1,351
