Ana içeriğe geç
Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement
Elizabeth Surface
Elizabeth Surface ve 3 diğer katkıda bulunanlar
En son January 18, 2021 tarihinde güncellendi
30 dakika - 1 saat
Zor
If your computer does not register that the Sony Cyber-shot DSC-HX300 is plugged in then the HDMI/USB ports may need to be replaced.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the camera is powered off
    • Turn the camera upside down. This is a view of the bottom of the camera.
  2. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: adım 2, 1 resimden 1.
    • Push battery cover away from the camera.
  3. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: adım 3, 1 resimden 1.
    • Push the blue tab that secures the battery. The battery will then spring out.
  4. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: adım 4, 2 resimden 1. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: adım 4, 2 resimden 2.
    • Remove the battery.
  5. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, Motherboard: adım 5, 3 resimden 1. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, Motherboard: adım 5, 3 resimden 2. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, Motherboard: adım 5, 3 resimden 3.
    • Make sure to remove the battery before disassembly to prevent electrocution.
    • Remove the 3 (4 cm) Phillips head screws located on the back of the camera.
    • Remove the 2 (4 cm) Phillips head screws on the right side of the camera.
    • Turn the camera upside down to remove the remaining the 3 (4 cm) Phillips head screws holding the plastic camera housing together.
  6. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: adım 6, 2 resimden 1. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: adım 6, 2 resimden 2.
    • Using a plastic opening tool, separate the plastic camera housing.
  7. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: adım 7, 1 resimden 1.
    • Disconnect the ribbon wire attaching the screen to the camera.
  8. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: adım 8, 3 resimden 1. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: adım 8, 3 resimden 2. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: adım 8, 3 resimden 3.
    • Carefully remove the 7 ribbon wires connected to the mother board.
    • Remove the 2 (5 cm) Phillips head screws on the speaker mounting bracket.
    • Remove the 3 (4 cm) Phillips head screws that secure the motherboard to the camera.
    • Lift up on the speaker mounting bracket to remove it.
  9. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: adım 9, 2 resimden 1. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: adım 9, 2 resimden 2.
    • Carefully disconnect the ribbon wire connecting the HDMI port to the Motherboard.
    • Once the Motherboard is removed the replacement can be installed.
  10. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, HDMI/USB port: adım 10, 1 resimden 1.
    • Remove the 3 (4 cm) Phillips head screws securing a mounting bracket over the HDMI/USB Port.
  11. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: adım 11, 1 resimden 1.
    • Lift up on the mounting bracket to remove the HDMI/USB Port from the camera.
  12. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: adım 12, 1 resimden 1.
    • Once the HDMI/USB Port is removed the replacement can be installed.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Elizabeth Surface
1.465 İtibar
9 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-6, Meier Fall 2015 USF Tampa, Team 4-6, Meier Fall 2015 üyesi
USFT-MEIER-F15S4G6
4 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 15
Her zaman: 1,647
